Autronic PnP on Stock Evos
Old Feb 18, 2004, 03:35 PM
evosevengsr's Avatar
Where can I find a autronic unit for my car.?Lancer evo 7 GSR.
the PNP board of course.
thanks
Old Feb 18, 2004, 03:46 PM
Also, I went to autronic's web site (www.autronic.com) and saw that they have a "replacement board" for my car.Is this the same as the PNP board?
thanks
Old Feb 18, 2004, 03:51 PM
gldenchld's Avatar
Yes it is the same Plug N Play board shown on Autronic.com, the board comes with a base map which is prettygood. We sell the board and can supply additional maps if purchased thru us and can do custom tunes. Either PM me or call 631-254-4871
-Zach
Old Mar 5, 2004, 10:40 AM
JFawns's Avatar
Hey does the autronic save the custom tuning information if you disconnect the battery?
Old Mar 5, 2004, 10:51 AM
CChow's Avatar
Of course!
Let's say your car battery dies. The Autronic maintains all information just like the factory ECU.
Better yet...if you are programming and either your battery in the car or battery in the laptop dies, the Autronic will retain all the information that was last saved.
Autronic is not vulnerable to car battery disconnect.
Old Mar 5, 2004, 01:52 PM
JFawns's Avatar
Great...thanks for the info!!
Old Mar 12, 2004, 11:26 PM
Sickdriver's Avatar
My question regards the ALS system.
Can it be hooked up to an external swithc or doea it habe to be turned on and off from the laptop?
Thanks
Old Mar 13, 2004, 02:34 PM
Mark S's Avatar
Hello
You can use a switch to turn on and off.
Old Mar 16, 2004, 12:53 PM
beerstream's Avatar
Sickdriver-
Here is a link you can check out. It doesn't show a wiring diagram but it gives you an idea.
http://www.autronic.com/software/antilag.pdf
Old May 8, 2004, 09:03 PM
AWD 20T's Avatar
I'm curious as to the gains in HP Evos have gotten with just the autronic installed using 91 octane... I'm in CA, so I don't have access to 93 at the pump...
Old May 8, 2004, 09:33 PM
evo_08's Avatar
alamo auto sports
Old May 18, 2004, 03:37 PM
cosmo's Avatar
Does the PnP autoronic for the Evo8 utalize the stock knock sensor, or does it still run without utalizing knock? Thanks.
Old May 24, 2004, 10:59 AM
beerstream's Avatar
No knock control. This system relies on the hands of the tuner. There has been much debate about knock control vs. no knock control. If you are confident in yours or your tuners knowledge then there isn't anything to worry about.
Old Jun 5, 2004, 08:02 AM
EvoG8r's Avatar
I have questions about the board.
Does the board work with electronic boost controllers or do you have to go back to the stock boost control solenoid?
How does this speed density thing work? It states on some websites that the stock MAF sensor is no longer used. Does this come with the necassary hardware to remove it?
Old Jun 15, 2004, 07:09 AM
EvoG8r's Avatar
Ne1?
Quick Reply: Autronic PnP on Stock Evos
