Autronic PnP on Stock Evos
#31
Hello
You can use any boost control with the Ecu, The Ecu does not have to control the boost if you have a stand anlone Boost controler.
The Ecu has a Mapsensor Inturnal so you dont use the AFM and can remove it, It doesnt come with the replacement pipe but anyone can make one.
Mark
Mark
#32
I've noticed that on Autronic's site that instead of running the regular smc, they are using a motherboard that fits inside the stock ecu box, (making it P&P). Not to mention the internal speed density sensor.
Just curious if any of you are using that, and how much is costed just for the system. And do you send them your ecu to be modded or do they send you one and you send back your stock core or what.
thanks
thanks
#33
The Autronic board does replace the stock board inside the stock case. Just remove, open, swap board, then reinstall. You don't need to send it anywhere to have the board swapped. I would have to check on the price.
#34
Can I download the Autronic software anywhere? I am interested in seeing how user friendly the software is compared to the UTEC, XEDE, and of course AEM EMS.
And what is the limit of Autronic ECU? I am just wondering why it is not as popular as other systems.
#35
The screen shots aren't that helpful?
There is really no limit to what you can do with the Autronic ECU. It is designed to drive low impedance injectors and the MAP sensor goes to 44 psi. The highest recommended RPM is 16,000.
I think I know why the Autronic isn't that popular compared to other systems...not as much advertisement and not a lot of technical support. The support is out there, you just have to know where to look.
#36
Speaking of user friendliness, I use a Windows 2000 laptop to connect, make changes and datalog. Accidental key-off while still connected to the ECU, it didn't matter. The Autronic never failed to perform. The screen NEVER froze on me and all changes to the Autronic were performed in real-time.
#37
CChow,
Can you please share your finding and let me know where else I can find more info and support with Autronic ECU? I am so ready to make a decision between AEM EMS and Autronic. And do you need (or do you have) a wide band O2 sensor hook up? I am wondering how Autronic can tune the car accurately with the factory narrow band O2 sensor.
#38
I usually go to the Autronic Forums lead by Steve Nichols. He knows his shiet, and I always get a response. The thing is, the Autronic PNP is just like I expected, plug and play. I have about 8 years experience on the MoTeC ECU, 9 years on the Accel DFI, 6 years on the Speed Pro (FAST) systems, so working with the Autronic software was exceptionally easy.
You don't need the wide band to hook up to the unit. You can ball park the readings using the factory sensor. I recommed purchasing the Innovate LM1 unit. http://www.tuneyourengine.com while tuning with the Autronic.
By the way, the LM1 has an analog output feature so that you can mount a narrow band gauge or output to the Autronic and you now have accurate A/f readings![Smilie](https://www.evolutionm.net/forums/images/smilies/smile.gif)
The LM1 unit by Innovative is about 350.00. It has an onboard datalogger and has inputs for RPM, a backlit display, yadda yadda yadda. It's awesome and allows me to tune on the street anytime of the day![Smilie](https://www.evolutionm.net/forums/images/smilies/smile.gif)
Technically, you could buy the AEM and do the same thing with the LM1. I also like the Autronic because it's PNP, no external boxes. It looks STOCK
But people will wonder how you can run monster size-low impedance injectors with the stock ECU
The only extra hookup is for an air intake sensor. The Autronic has an on-board pressure/vacuum transducer.
Speaking of which, you can pull out the PNP unit and drop the stock ECU board back in if you want to sell your EVO at a later date. Then sell the PNP unit and recover "some" of your initial investment.
Chris
![Thumbs Up](https://www.evolutionm.net/forums/images/smilies/smilie_thumbsup.gif)
Chris
CChow,
#39
Ooops here's the link to their company
#41
I was told you couldn't do this. Will the AEM wideband hook up to the Aitronic plug n play board?
#42
No it wont work..
To use LM1 with autronic you`ll have by the Innovatives Autronic cable or you can use the LC1.
Cable
LC1
Check the Innovatives forum for more info
#44
No. To the best of my knowledge either use the LM-1 or LC-1 or the expensive Autronic one
Originally Posted by sayanara
are the fjo systems compatible with autotune?
#45
PLX
I have the autronic PNP on my Evo and a PLX wideband. my friend/shop owner is a Autronic dealer and has the $1600 Autronic analyzer. We went out driving the car one day and the PLX analyzer read identically to the Autronic wideband. I have a resistor network to change the ground voltage signal so it is the same as the Autronic analyzer. That is the reason any other wideband will not work with autronic. I have also used an LM-1 with autronic and it is very laggy. I dont care for how it reads at all. It is not as fast as the PLX. the AEM will not work at all because it uses a different readout. also, narroband is worthless.
