HKS EVC 6 issue
HKS EVC 6 issue
hello there ,, in fact am useing the hks evc 6 and its very great EBC !!! but i faced issue that made me feel sad ,,
i set everythings and the boost is steady all the time but once i shift between the gears the boost fall down , than back to my target boost !! my target boost was set to 1.6 bar !! once i shift to next gear it droped to .9 bar !!
i do not know why is that ??
when i was useing the greddy profic 2 , it did not happend !!!
what should i do ???
thanks alot
thanks alot
thanks alot
thanks alot
3000 4000 6000 7000 8000
Boost Correction Map B -17 1.6 1.7 1.8 1.8
Offset Map B 100 100 100 100 100
well this is how the boost wiring in my car !!! running twin turbo GT3076
is it better to connect the WG vacum into the turbo housing ??? will this fix my problem ??
is something wrong that make the boost drop into gears shift ?? btw am running tiptronic auto car
Everything looks good, its going to drop thats normal it should go right back to whatevery you were at pretty fast. The greddy more then likely does not react as fast. The drop is normal its just the excess boost blows out when you shift/the car does and then it takes in more air as it now will be in a higher load set with a higher gear.
