Anti Lag System
The one time I went to the drag strip I pulled 1.80 60's on all seasons. There was some slip, but for the most part it hooked up pretty well. If I had more or I guess any at all experience launching the car at the time it should have been much better.
www.autronic.com
Most any reputable shop should be able to get it. I got mine from Lightspeed Innovations (AB,Canada)
That is incorrect. The more advanced answer to your remark is you need to achieve at least -30 degrees and consistantly. The Autronic is a way more capable tool or ecu than the stock although it is remarkable what you can do with the stock ecu and AEM you will not be able to run achieve ALS or even a good SAS.
EvoLutionized8
European Forum
11
Jul 18, 2006 01:30 PM
