LTFT fluctuation?
LTFT fluctuation?
I have seen a few threads about LTFT. But my question is can it help determine AFR if you are lean or rich and what is the acceptable LTFT on an evo x I have been anywhere from 0 to 3.9% is my ecu still learning or does it change that much from day to day?
Thanks for the reply I meant to be in the x management/ forum area if a moderator could move my post that would be great. I did see the +- 5% is ok so you confirmed my research. It seems that LTFT should be less variable but who am I to say how a tune should be im a novice. ive seen + 3.9 to 0 in one non wot trip seems like the ecu is always learning as apposed to learning and running with it.
ecktt
May 8, 2017 06:18 PM
zikizira
17
Apr 9, 2010 04:25 PM
12, 20, accessport, afr, changing, cobb, evo, evom, fluctuates, fluctuating, flucuating, ltft, repeatedly, subaru, trims
