Will 4G64 Crank Fit in 4G63
I believe there are more technical details than simply putting in a larger crank. Engine size is what displacement is not necessarily crank size alone. The block is bored larger in a 4G64, meaning that the pistons are larger and heavier, thus requiring the larger crank.
i was told u can use a 4g63 block with 4d68 150 mm rods and 4g64 100mm crank with vg30 pistons
senate6268
128
Sep 3, 2015 10:44 PM
WTB[Northeast]: 4g64 block and oem crank.
Evo3573
22
Dec 26, 2014 07:32 PM
hybrids14
Mar 19, 2007 01:06 PM
100mm, 4g63, 4g64, block, bore, crank, crankshaft, dimensions, evo, evolutionm, exedy, fit, hd, price, sale
