Can't seem to hold 2500rpm? Tune?
Hey everyone I recently brought my ix in to have smogged and the technician couldn't hold it at 2500rpm?? I thought it was just him so i hopped in and tried it...no luck, got under the hood...no luck. When cold i can slowly raise up to 2500 but when the motor is warm once i hit 2100 slowly it just climbs up to 3k? It idles fine, just around 900-1k for me. I got it to pass by bouncing the throttle for the alotted time but I'd still like to fix this issue for next time. Is this a tune issue?
Current mods: aem CAI, TBE with test pipe, cams 264's, walbro 255, Ecuflash by cbrd.
Any help would be appreciated thanks!
So I checked all the vac hoses and nothing is cracked or popped off, I also threw the stock intake with high flow drop in back in the car and it still does it. Any other ideas? If not I guess im looking at a new tune
I've checked the vac hoses, after speaking with CBRD I'm going to have it retuned before I check out anything else. The previous owner tuned the car on 93 octane in PA and then brought the car here where I can only get 91 octane.......wish I knew that earlier. If that doesn't fix it then i'll check the throttle body.
babaz7
Mar 24, 2016 02:09 AM
Jamesm331
Feb 29, 2012 08:32 AM
EyeDreamt
Feb 9, 2011 01:26 PM
