Got my wideband completely hooked up, need help.
I installed 3 widebands this weekend including my car, and all the other car's (Rustangs) worked out just fine. I calberated mine twice and got the same results. I made a few vids i'll post in a min:
WOT: 11.5's
Idle:14.5's
Decelerating: 20's
Regular driving: 11's
All of a sudden after letting it idle for a few minutes the wideband would show 18 and the car will start idling under 500 and after a few seconds go back to normal. Mod's are in my sig! It's a innovate LC1 wideband, every once and a while it will go less than 9 and jump back to 14, none of the other cars did that. Please tell me if this sounds about right!
WOT: 11.5's
Idle:14.5's
Decelerating: 20's
Excuse my ****ty driving skill's, i was alot more focused on the gauge than anything else.
http://www.youtube.com/watch?v=2Hc5a...R6ORsA&lf=plcp
http://www.youtube.com/watch?v=8uLm0...2&feature=plcp
http://www.youtube.com/watch?v=aPJFi...1&feature=plcp
If it is showing 18 and idling down that much chances are it is going lean for some reason. I would think a boost leak test and maybe check the tune then go from there. Doubtful but possible you have a bad sensor.
Then definally should do leak test.
If you can install wideband urself, im sure you can do this.
https://www.evolutionm.net/forums/ev...er-5-02-a.html
on my way to home depot, thanks man!
WOT: 11.5's
Idle:14.5's
Decelerating: 20's
WOT: 11.5's
Idle:14.5's
Decelerating: 20's
mister1161
Feb 20, 2016 03:51 AM
gsteensland
May 22, 2015 09:07 PM
