Need Help ASAP fic 850's wont scale
I bought a set of "FIC 850" injectors id number "125-0850" and the other numbers are "4257 17113743"
Issue is we can not get them to scale to idle. We have tried every number.
The last owner said he has no idea he ran them on his car and said that they were hard to tune but after ran fine...
Need help asap I have to drive the car 8 hours 1 way to a rally in NY and cant unless I can figure out the injector scaling. I can log and post anything thats needed please help!
I have tried 770, 696, 713, and many other...closest normal idle was a much lower number around the 500-600 range???? Any ideas? I am still a noob at tuning but have had 2 well known tuners try to help with the free time they have (not much) so anything can hel.
Mods are...
Stock MAF
New Built head 1mm over valves, GSC 274 cams.
Jdm map
Upper and lower Ic pipes
Stock intake manifold
Egr delete/emissions delete
No rear o2 sensor
Aem wired to pin 75 on ECU
E9 turbo
3" straight pipe
FIC 850 injectors
Email is Twistedshot101@aol.com
Pm for cell
Help me get to Rally New York!
Mods are...
Stock MAF
Jdm map
No rear o2 sensor
E9 turbo
3" straight pipe
FIC 850 injectors
Pm for cell
All I have is the base setting for 770 and 696 tried everything.
Sitting in the car now it runs lean on my AFR with almost all of the base settings
Any recommendations?
Car wont idle with this o2 trim is stuck at 24.80
FIC 850
Scaling 696
Latencies
1.2
0.768
0.504
0.36
0.312
same for this sits at 24 o2 trim
FIC 850s
Scaling 770
voltage-
3.312
1.68
1.032
0.84
0.552
0.456
0.36
We just set it at 430cc.....
and .408 14 volt and its idles...
FIC 850
Scaling 696
Latencies
1.2
0.768
0.504
0.36
0.312
FIC 850s
Scaling 770
voltage-
3.312
1.68
1.032
0.84
0.552
0.456
0.36
FIC 850
Scaling 696
Latencies
1.2
0.768
0.504
0.36
0.312
FIC 850s
Scaling 770
voltage-
3.312
1.68
1.032
0.84
0.552
0.456
0.36
FIC 850
Scaling 696
Latencies
1.2
0.768
0.504
0.36
0.312
FIC 850s
Scaling 770
voltage-
3.312
1.68
1.032
0.84
0.552
0.456
0.36
Try something like this....
Scaling 770
voltage-
3.312
1.9
1.100
0.88
0.70
0.58
0.45
Just replaced the o2 sensor. With the new head build.
We are getting closer!
Best Numbers we had were
680
1.008 14V
We are dropping to
665
1.008 14v
Fuel trim is at 0 at idle around 950rpm
No low or mid trims are logging
680
1.008 14V
We are dropping to
665
1.008 14v
Having the same issues with FIC 950s and AEM wired to pin 75. Mine seems to start and idle okay at rich AFRs with lower scaling but won't start at recommended scalings. Fuel trims are 0 for some reason. Hopefully we can get this figured out.
I agree Start with your base number but set your 14v to a much larger number my base was 770 and .552 14v but its running much better with
650 scaling
1.2
0.864
1.008
0.384
0.336
650 scaling
1.2
0.864
1.008
0.384
0.336
2.3
1.68
1.15
1.008
0.88
0.65
Thanks Ill give that a shot now.
Just took a 30 mile drive mid trim logged a -4.88 at idle my o2 feedback is within 5 most of the time but does go 10 and 15 at some pounts idles at around 14-15 AFR fuel trim low is -0.7812....
Just now its sitting at 0 o2 trim and 13.4 AFR
