AFR and Cold Weather
1 Post
My car was tuned in OH around 55 degree weather. Idle AFR reading was 14.7 give or take. Now, in this 10F Nebraska weather, I noticed AFR's been leaner..idle around 15.2 or so. I don't notice any boost spikes. However, I think WOT is around high 11's. EBC is set at 11 min 19 max. It was tune at 19. Should I reduce the the boost during the winter? How many psi should take off?
1 Post
I have the Profec B Spec 2 which seems very difficult to configure. It's not like the EVC simple Hi=19 PSI. I wouldn't know how to lower pressure. The tuner set the low boost to 11 PSI. Would dropping down from 19 to 11 be destructive to my engine?
1 Post
Also, during cold start, I noticed the AFR jumps between 15-15.8 and everything in between and three times, it jumped to 16 for a split second. All this within 15 mins. Once the car is warm up, it still bounce between 14.9-15.6, no 16s. Searching, everyone says during warm up, you run richer. Should I be concern? Is this due to the cold?
Raceghost
Feb 11, 2017 10:27 PM
papabeardoe
Jun 12, 2016 03:27 PM
