Stock ecu vs aem ems
Hey guys I'm going to to be running 6466 with all supporting mods I am wondering if it would make diff if I went with aem if car will make more power, along with benefit.
both will make the same power when using speed density. i only used aem a handful of times, but it was easy to figure out each time i did. the stock ecu requires more digging/research, but if you're not tuning the car yourself it doesn't matter.
do whatever the person tuning your car recommends.
my personal advice is keep the stock ecu though.
yes and it has boost comp tables where it will self adjust afr etc based on boost pressure. aem is nice, but not good enough to get me to remove a perfectly good stock ecu.
when tuning it on other cars though it is a really nice ems. its very user friendly.
the stock ecu has live map DMA stuff also, but i don't bother with it.
boostawd16
Jul 3, 2015 09:09 AM
Hakmeister
Jan 12, 2010 02:29 PM
