emanage not working right after install
i just installed and updated the e-01 and emanage. i checked all thw wireing 4 times... im sure its correct. i have injector/and ignition harness installed. the car drives funny with all settings at 0. i thought it should drive normal. i never saw anything that depected where to find the sensor type... that may be the problem. when you were first initializing the emanage, did you have to change the sensor type to karmen? or was it already set to it? where is it to set it?
Originally posted by rt turbo
yes. im concerned that i had the wrong sensor selection type. what should it be set on?
