Check Engine Light EVO IXGSR
Old Apr 9, 2014 | 05:22 PM
DONNOD's Avatar
Guys,
I need some advice .
EVO IX is throwing engine light, code is P0505, IAC system. But Idle seems to be fine, not rough, stalling etc.
Only problem car does is, hesitant to accelerate over 3500rpm and not always though, very often. Seems like its worse during hot weather.
I did perform ECU reset and the light comes back ON again, especially when driven a bit HARD.
I have only cleaned the MAF and air filter so far. Spark plugs are NGK Iridium. Car has 155k kms,
mild mods:- Turbo Back system, perrin silicone pipes, 8MR BOV, aftermarket ECU Flash.
Please shed some light.
Thanks
Old May 1, 2014 | 11:03 PM
superkizuna's Avatar
How is your car idling? Does it idle very high for a time?
Old May 1, 2014 | 11:10 PM
shrtstuff89's Avatar
Plugs are gapped properly?
Old May 2, 2014 | 12:03 AM
Originally Posted by EvolutionBrian
just disable the light
Don't ever do that. EvolutionBrian, maybe you should stop posting answers like that to people's questions. That 'light' is one of the most important ones in the whole god damn car bro.
Old May 2, 2014 | 04:24 AM
DONNOD's Avatar
Yes I did that first. 😋
Old May 2, 2014 | 04:26 AM
DONNOD's Avatar
Yes it does on cold start sits just under 2k and for a few minutes and then drops 900 - 1k rpm. Cheers
Old May 7, 2014 | 01:40 PM
MuchSpoolWow's Avatar
sounds like running in limp mode..
Old May 7, 2014 | 03:24 PM
DONNOD's Avatar
Fellas, thanks heaps for all advices, it really helped me a lot. It was a leak on the upper intercooler- T/body outlet hose. I replaced the stretched hose and factory clamps with TBolt. Car is driving fine and much responsive, no CEL whatsoever. I'm gonna replace the IAC valve as well, since I heard it is a trouble maker too 😃. Cheers
Old May 9, 2014 | 06:42 AM
sexydexy_evo4
Sep 28, 2016 09:41 AM
Stellybeats
Feb 21, 2016 03:57 PM
whitedsm97
Mar 23, 2015 11:10 AM
strud
10
Apr 21, 2010 12:55 PM
EVO8speed
Dec 1, 2008 08:05 PM
