Cel on but no dtc after new map
My tuner loaded a new map wherein we adjusted for throttle hang and idle dip, car seems pretty ok after the new map however my cel started to come on and everytime i check the codes from my generic obd scantool it says that there are no dtc and it just tells me to unhook the baterry for 5 mins. But when i do that the cel comes back on after driving for 5-10 mins everytime. No matter how much times i unplug the battery it just keeps coming back. I also noticed that some of my scantool features are no longer accessible after the last map like live data and actuator testing. But before i had access to these features with no issues at all. Could there be something in the map causing this? Should i be worried about the cel? I already talked to the tuner about the issues and decide that we will load back the last map prior to the idle adjustments we made, problem is i have to wait for him in about 3 weeks and the cel is getting me restless a bit. I also went to the mitsubishi dealer to try and get dtc if any but their scantool wont connect to the ecu as well, before i already took it to them and their scantool was able to connect. It makes me wonder if the last map would cause these issues? Thanks for the help guys.
evo4mad
May 5, 2015 06:22 PM
AlwaysinBoost
15
Nov 5, 2011 10:45 AM
