pictures of my utec install.
hehe.. That looks like his laptop.. The UTEC's chassis/bracket is large, it houses the UTEC circuit board, and the stock ECU.. it bolts into the location the ECU came from, which is behind the glove box.. Its actually almost the same size as that laptop but not as tall.. Its about 7" high by 12" long by about 1.5-2" thick..
Originally posted by Mitchubishi
So it won't be protruding out of nowhere right? Whew, was worried about that for a second. I'm guessing that little silver box is the "tuner"?
It is a product engineered for the EVO8, not a universal product we've tried to cram into the space behind the glove box. Unless you take your glove box off, you'd never know it was there.
The Silver box is the tuner. It is a universal product that is a little harder to mount. The best solution is to leave it in the glove box and use the Gameboy as a display when it's available. You get more information from the Gameboy then you do from the front of the tuner anyway. The Gameboy smart cable will also let you tune and log your UTEC.
-Nathan
evo9atic
Mar 29, 2017 08:39 PM
bruster
177
Dec 17, 2014 09:57 PM
js3324
Apr 21, 2007 12:08 AM
