Leaning out?
Leaning out?
Hi
I suspect my evo may be leaning out on E85. the car is fine to drive at low revs but once i get to full boost and higher revs around 5k or so it starts to get little backfires and shudders and loss of power. It happens worse in the cold so i suspect the colder air is causing this to happen.
Im running 450 hp 28 psi with 1060cc injectors
You really need a gauge to monitor if it's leaning out or not. Leaning out some on E85 probably wouldn't cause what you're experiencing though. You might be developing a misfire and need to change your plugs. I would check that out.
Z_Lancer_Man
Lancer Aftermarket Forced Induction Tech
Aug 1, 2006 05:55 PM
BoostWhore
Dec 25, 2005 11:08 AM
