Evo 8 ECU in Evo 6 Running Rich, close to 10
I have an Evo 8 ECU swapped into my Evo 6 and it runs fine but it runs very rich - about 9-10 on the AEM UEGO. Could someone take a look at the rom ?
to support the FIC 1050's, Injector scaling is set to 1008
injector voltage latency compensation is set to
4.44
3.192
1.752
1.032
0.84
0.5760000000000001
0.432
I have attached 2 roms.
One is the stock Evo8 Rom with FIC 1050 injectors. - Runs Lean -17 to 18 and higher AFR at idle and cruise
The other is a Tephra ROM with FIC 1050 modified specifically for Evo 8 to Evo 6 Swap. 10 or less AFR at idle and cruise.
I will get a pro tune eventually, but car needs a bunch of maintenance and still a bunch of mods left to do. Id like to get a decent tune going in the meantime just to drive it around a bit.
4.44
3.192
1.752
1.032
0.84
0.5760000000000001
0.432
Should take it to Magnus Motorsports (should be close to you if you live in Toronto) and get it dyno tuned http://magnusmotorsports.com/contact-us/
They will sort out the fueling with the tune.
Ok will try playing around with those. I've run these injectors for a long time with these values previously on an Evo 9 and on my Evo 6 with the Evo 6 ecu.
It's only been an issue with the Evo 8 Ecu swap which is why I doubt it's an issue with scaling.
dli03
Apr 23, 2010 06:00 PM
Evo8Emperor
Nov 4, 2007 06:24 AM
Nerologic
Jul 11, 2006 11:33 AM
CACalomino
May 20, 2004 12:21 PM
