Anyone using the ARC intake with the UTEC
The EVO UTEC has been available for some time now. I actually should re-ask the question as who has the ARC intake and maybe plans to install a UTEC.
I will explain the reason I am asking this based on the responces.
We tuned one with the ARC intake. The map was weird, but not as bad as the one you guys did. It ran around 12.7:1 AFR on the stock ECU at totally stock boost.
As we turned up the boost the box seemed to read a little better, but we still were a far ways off from the stock stage 1 map.
-Nathan
-Nathan
I've got the UTEC in my EVO. The best that Ron @ Axis Power could get for A/F's w/ the HKS RS was high 12.5. I am putting my stock airbox on today!!!!!! I think that the intake is way to close to the MAS. The hot intake temps have got to be throwing it off. Just my thoughts.
"ErnieT" you are of course correct. The issue with the ARC intake is that it does throw off the MAF sensor readings. This means that the TurboXS base map will not work correctly.
You can see the effect of the ARC intake by simply logging the short term and long term fuel trims via the OBDII port. With the ARC intake installed we saw these at +18%. The ECU was dumping in loads of fuel to compensate for it.
A UTEC map for this intake requires a completly different fuel map which also includes 0% fueling.
Nathan - Were you refering to the fueling or the timing. The timing was very conservative in our map. This was two fold, crappy 92 Octane gas and customer worry. I wanted to make sure they had no knock issues. Customers removed this intake now so I doubt I will get a chance to fine tune it. Shame really I like a challenge.
Mick,
The one we tuned was not as bad on the fuelling side as the one you tuned. It ran at richest 12.7:1 under stock ECU control. It would have been nasty with the basemap, but I knew what to expect since you had given me the heads up.
-Nathan
-Nathan
Originally posted by ErnieT
Your intake has nothing to do with your a/f ratio. If your lean, which 12.5 is lean, then you need more fuel.
tonights dyno hp / torque
boost and a/f
Peace,
Jeremy
has anyone thought of this......you put on a metal intake tube that runs right behind the radiator. Ime quite sure it gets hot under there. Real hot in AZ. so the intake air is heated up also. But the rubber intake is well rubber and will not transfer as much heat to the incomming air. Can this make a difference??? I am REALLY thinking about putting my stock airbox back on too..... RRR
Well I had a very good tuner (Ron @ Axis) tell me to put the stocker back on, and I went from 258.9 whp to 287.4 whp. no other change than the intake and the appropriate tweeks because of the intake change. Hmmmmm?
So, the fact that the HKS filter sits right on top of the MAS has nothing to do w/ A/F ratio? I put my stock air box back on tonight and had it re-tuned at http://www.axispwerracing.net and holy hell, what a difference. Same tuner, same fuel pump, different intake......?????? Am I wrong here? Please let me know.
Peace,
Jeremy
Peace,
Jeremy
I wasn't trying to start a war. I've had a few fast cars in my day. My last was a 10sec RX7 daily driver, which has to be tuned perfectly or your lookin at a new motor. The HKS filter sitting so close to the MAF may give you some different readings and send your intake charge temps. a bit higher, but on a dyno, your not under load, so an intake is not going to make you run leaner or richer. Ask your tuner.
jeremy
no war started. i'm just trying to learn about this stupid MAS. i understand what your saying about the load, but what gives? the difference was huge, in favor of the stocker?
jeremy
jeremy
