New Evo owner - need some guidance
Old Jul 20, 2017 | 08:05 AM
Rocky_D's Avatar
Hi
I recently bought a 2003 evo 8. The car has some modifications and has a tune. Can someone in the know take a look at current tune and tell me if there is anything that jumps out at them that should be addressed? I'm planning on taking it to a dyno soon. This car is becoming a "hot topic" at home with the wife so dyno is going to be little bit.
I'm in the Hudson Valley, NY. Any reccomended reputable dyno/tune shops in the area are welcomed.
I just did the intake and intercooler piping, cat delete and exhaust. Since, the car has been kinda funky to drive. it feels like a dog from start to about 4,000rpm, Its bucky when I start out and in between gears. It also feels like its being held back in terms of power. I'm probably not describing these things properly but that's how it feels to me.
Also, is there an option to include a 2-step when tuning? or is that a separate thing to install?
Current mods that I know of
BC 272 Cams
Wahlbro 255 Fuel pump
Stock injectors
10.5 hotside
HKS Downpipe
Cat delete 3" test pipe
DC Sports 3" full exhaust
ETS Lower intercooler pipe
Injen intake and piping still have MAF
Forge BOV recirculating
Manual boost controller set at 20psi currently
koyorad radiator
Any information anyone can provide or share I totally appreciate.
Thanks!
File Type: hex
Old Jul 20, 2017 | 02:02 PM
J_Striker's Avatar
Might try posting in the ecu tuning area.
Old Jul 20, 2017 | 03:04 PM
Rocky_D's Avatar
Thanks. Can someone move this to that section?
Old Jul 20, 2017 | 04:38 PM
Done!
Some of the guys will chime in
Old Jul 24, 2017 | 08:19 PM
Rocky_D's Avatar
Anyone have any input?
Old Jul 28, 2017 | 11:21 AM
Rocky_D's Avatar
I hear crickets in here.
Old Jul 28, 2017 | 11:38 AM
Ill see if i can summon some help but I can access this file? Is there a better file extension that can be used? (i.e. PDF or JPG)
Old Jul 28, 2017 | 11:40 AM
Rocky_D's Avatar
Thanks. That's the file pulled off my car through ecuflash.
Old Jul 28, 2017 | 12:13 PM
Most logs Ive opened were done in Excel & they were zipped
Old Jul 28, 2017 | 12:24 PM
Rocky_D's Avatar
Ohh ok. This isn't a data log. It's the current tune that's on my car. I guess I should do some data logging with evoscan?
Old Jul 28, 2017 | 01:14 PM
Heres a common log attached
File Type: csv
Old Aug 5, 2017 | 12:50 PM
Rocky_D's Avatar
Deleted
Old Aug 5, 2017 | 12:51 PM
Rocky_D's Avatar
Edited
Old Aug 9, 2017 | 09:58 AM
cts4g63's Avatar
I know you just put a new exhaust system on it, but seeing that you're from NYS I would highly recommend putting the stock exhaust back on it, getting it inspected, and then modding/tuning the car. That is, unless you don't intend on having it inspected. Good luck. Sounds to me like the car needs a proper tune.
Helmetface
Oct 1, 2017 06:51 PM
Ceramik
Dec 12, 2015 10:12 AM
shrty10135
Dec 30, 2012 09:48 AM
mastablasta
37
Mar 10, 2011 10:36 AM
marios23
Feb 22, 2011 05:40 PM
