Lamspeed speed density conversion kit
Has anyone had experience, good or bad, with the lamspeed speed density conversion kit?
Lamspeed Racing Mitsubishi Evolution 7/8/9 CT9A Speed Density Kit to s
I'm pretty sure my AFM needs replacing. And in my country a new AFM ranges from $1200-$1500, but the Lamspeed kit is half the price.
What is the AFM you are referencing?
You can buy the parts for the speed density conversion much cheaper than this kit as well. Omni 4 bar ($100), spoolin up harness ($25), GM IAT sensor ($40) plus shipping.
You can also skip the IAT if you want and use the fuel temperature sensor on the car. It isn't ideal but it does work. I have been setup like that for years.
It's just another name for the MAF. But in my country calling it AFM is more common so it's just a habit.
Thank you so much for the information about piecing the speed density kit together. I didn't realise it was that easy. I do actually have an Omni 4 bar and a GM IAT already sitting here. I didn't know about the spoolup harness, that makes things much easier for me. Appreciate the advice
I will go Haltech eventually but for now I'm just trying to keep it running as the MAF appears to be dying and I didn't want to spend $1500 on a replacement one only to go Haltech eventually anyway
schuhie (Jul 9, 2024)
AFM is Air Flow Meter
Yea, its super simple to piece a conversion together. Like I said too, the IAT is the right way but you can simplify even more if you just use the fuel temperature sensor. I plan to add an IAT eventually but have been waiting til I re-powdercoat the upper IC pipe so I can add the bung and switch to a tial blow off valve at the same time to clean up the bay. It has just been years bc I haven't wanted to mess with it lol.
I really want to move to a PnP Haltech setup as well. It seems like it offers a lot of great function that the stock ECU doesn't have but again, my car has been solid for like 5 years so its hard to justify the cost. One day lol.
Good luck with the setup! Should be pretty straight forward once you get the sensors in place.
WTB[West]: 5 speed conversion kit
Paulevo9
Oct 28, 2015 08:51 PM
MRblack06
Aug 24, 2014 05:03 PM
Muck
Oct 3, 2006 04:16 AM
