Help with Power-FC D-Jetro
I just installed a Power-FC D-Jetro on my car. The car started up on the first try and everything. I was going through checking the sensors on the commander and the PA (atmospheric Pressure) sensor reads zero.
Can anyone verify if it is supposed to read zero?
TIA
TIA
confirmed!
I figured there was something wrong with the PA sensor and it was causing the ECU to see a lot more boost than there actually was.
Any ideas?
You are not hitting 2 bar maps. The highest map mine goes to which hasn't been altered at all from Apexi is 26000. Which is actually 1.6 kg/cm2 or 22.75 psi. There is some formula in the manual to make the 26000 = 1.6. I didn't get it at first either.
i think i was confused about what you were asking...please retract my last statement....lool..
also ...
will it erase all settings if you disconnect battery...i called apexi and they said no ...but then they also said make sure to write all of them down just incase...
also ...
ASTROEVO
In the etc. menu. Where you can check the voltage readings for all the sensors. Locate the Boost sensor voltage reading. Right under it there is a voltage reading labeled only as PA. The manual identifies PA as the Atmospheric Pressure. Leo's reads 0 volts. He wants to know if that is normal.
Thanks for checking. I really don't know what that sensor would be for. What I really don't understand is why leo's car is running at higher load sites in the fuel and ign. maps, than the actual boost its running. Anybody got any suggestions?
Fas4dr
21
Jul 28, 2016 04:22 PM
DYE-04
Dec 31, 2008 12:48 PM
