Tuner A/F graphs
Originally Posted by jason9080
no I didn't meant you
I think Jason directed his question to me.. What I meant was without adequate tools, its not safe to play with the timing or afr's.. if you want to tune your car, you will need a wideband..
The good news is the Stage2 map is designed to work with their exhaust (stage 2 package) and you can bolt it on with good results... If you start deviating from the stages and upgrades, then you have to have it tuned to take advantage of the changes and give you the safest tune, that should either be done professionally if your not experienced with tuning. But you can do it on the street if you have a boost gauge, EGT gauge, and Wideband O2 setup (TurboXS Tuner is the best )
Spun Autosports
Evo 'For Sale' Engine Internals and Drivetrain
25
Jun 4, 2007 03:42 AM
201Motorsports
12
Sep 30, 2006 09:09 AM
PaganImmolator
Feb 22, 2006 03:57 AM
