Another new toy...Bee Rev limiter!
Sale price: $265 shipped
Click here for the fireball clip.
Bee Racing Rev Limiter:
The unique REV LIMITER from Power Builder Bee Racing is a device where a driver can use to prevent a vehicle's engine from being over rev. All parameter adjustments on this device can be made on the fly from the driver's seat. This REV LIMITER is achieved by cutting off the ignition at a preset RPM limit, and by re-routing a fuel dump. An aural feedback of back fire popping sound from the exhaust muffler is the result followed by a fantastic visual of fire coming out from the exhaust muffler tip. This aural & visual feedback are very similar to those experienced in the fully race-tuned race cars .
The rev limiter in the vehicle is controlled by the factory ECU by instructing the fuel pump to immediately stop the fuel supply to the engine. Such immediate forced fuel cut is not advisable if it happens frequently as it has damaging effects to the engine in the long run. On the other hand, with Power Builder Bee Racing's REV LIMITER, it actually cut off the engine ignition without stopping the fuel supply to the engine. With this function, over rev limit damage to the engine is prevented, and is a safer way in the long run when the engine is over revved past it recommended RPM limits.
The visual effect of having fire spitting out from the exhaust muffler every time there is a rev cut when the REV LIMITER is installed is not guaranteed by Bee Racing. This is due to the fact that fire would only result during high engine revving, and when the exhaust muffler is warm up, and also when the vehicle exhaust system is without a catalytic converter. Basically, the unrestricted vaporized fuel supply when ignition is cut off is lighted off when it mixes with the air from the engine air intake in the hot exhaust system. The hot temperature from the exhaust system is the catalyst that ignites the air-fuel combination in the absence of the ignition sparks.
Wire set up:
R E D - IG12V /Please refer to the wiring diagram supplied in the installation manual, and connect it to the designated vehicle's ECU.
BLACK - Connect this wire to theh vehicle's chassis' earth/ground contact, or the the vehicle's battery earth/ground terminal.
YELLOW - This wire is for the RPM signal. Please refer to the wiring diagram supplied in the installation manual, and connect it to the designated vehicle's ECU.
GREEN - This wire is for the ignition signal. Please refer to the wiring diagram supplied in the installation manual, and connect it to the designated vehicle's ECU.
WHITE - This wire is for the side brake switch signal. REV-1 works without connecting it.
SET-UP and SWITCH
REV-1: To set up standard RPM.
REV-2: The white wire connection set up the RPM readings that corresponds to the side brake switch signal. It works using an external switch. It switches off the engine by inputting a negative signal.
GAIN: Controls the engine RPM cut off setting. For example, o is off, and 1 ~ F is the adjustment range. The standard initial setting is 6.
Free shipping to lower 48 states
CA tax apply to CA residents
Thanks,
Tom
Wire set up:
SET-UP and SWITCH
Thanks,
Tom
Off topic... but I asked the dude who runs Bee*R (I can't recall his name), who I ran into at an IDRC race a while back when they were campaigning the GTO, where he got the company name. He told me to look at the name again... ahhh... made sense. BeeR. His favorite beverage. Some anecdotal stuff for laughs
Doesn't sound like antilag. Sounds like just launch control, with a set limiter. But reading looked like it only set a single limiter? If not then it is pretty cool but the UTEC is adding it soon, and you can get that for like 900 bucks including tuning of fuel and ignition and a bunch of other stuff, so almost 300 bucks for this isn't really the best.
Works alright I guess with flash users or AFC.
my car was spitting flames before i installed the utec and took the rev limiter out...and NO this is not Antilag. I dont get it, if you bounce your car off 7500 and you dont have a cat your car will shoot flames 90% of the time anyways.... so why spend $265 on something that is already there?
Edit* most people are taking there limiters out!
Originally Posted by xepyt
update?
Thanks,
Tom
It will inadvertently build some boost, however since it's not a traditional 2-step launch control or ALS, it will not build the same amounts. The built boost, is a side effect of the rev limiter doing its job.
If you're looking to build boost, I'd look more into a launch control specific item. I believe Bee*R also sells a launch control/2-step product.
