tsi setup pros and cons
#31
The highest we've ever seen the fuel pressure is around 120psi. Doesnt matter how big of a FMU you use and walbro pump. FMU's arent really the way to go on big boost.
#32
You can't go past pump limitations... a good intank pump will do about 120psi. (example... walbro 255lph high output) I've seen other intanks rated lower put out as low as 70-80psi.
I've seen out of tank pumps creat up to 250-300psi though... but that was fueling a 1000+ hp application and the fuel regulator themselves never let it get that high... test was done on static system for leaks/strength.
#34
i finally got my kit put on, i have the non ic'ed kit right now , im also automatic, unlike ryan i have my maf on the intake side, and only fuel mods ihave right now are the 14:1 fmu and bored fuel rail, its runnin at set 6 psi, so far i havent had anyproblems with it, had it on now for 2 months everythings runing good
#36
#37
All you have to do on the downpipe is cut it about 2 inch under the flange that connects onto the L pipe off the turbo and extend it about 2 or 3 more inchs. Get your exhaust shop to do this. Should be cheap and easy for them to do. Also, put a O2 bung under the flange for your up stream O2.
I have the TSI kit and intercooled it. Good kit just took a little moding.
#38
I have the TSI kit but have no clue how to use the injection control unit. What should the settings be? Someone told me to just ditch that and use an FMU i have an FMU sittin there but its not hooked up to anything.. What should i do?
#39
Just ditch it and use the FMU for low boost. I run 5 to 7lbs depending on gas prices. LOL
Hook it up by taping it into the return fuel line on your fuel rail. T the vac line off the line going from the manifold to fuel pressure regulator on the rail. If you still have question on hooking it up go to vortech superhargers website and look at one of the install manuals.
#40
Gentlemen, How about an update on the TSI turbo systems? It's two years later, are there any problems with reliabilty?
Is it true that no one can stay at the original 6 psi for very long, or have any of you left it alone and stayed dependable?
Sicktght311
Lancer Aftermarket Forced Induction Tech
42
Mar 30, 2018 01:13 AM
eastcoastoutlaw
Jan 21, 2013 06:12 AM
rchangwu
17
Feb 21, 2007 03:57 PM
