Vortech FMU and you...
Old Jul 10, 2005, 11:09 PM
HobieKopek's Avatar
Are you sure something else didn't cause the FMU to fail?
Old Jul 11, 2005, 10:26 AM
Lancerguy'03's Avatar
bump it up...i know someone has ideas....
Old Jul 11, 2005, 01:53 PM
imapunkclaimer's Avatar
mines working ok as far as i know, but hotshot said he opened his and some screws were loose or something and he was leaking fuel. ask him about it
Old Jul 11, 2005, 02:21 PM
Go2fast's Avatar
Call vortech and talk to those guys over there. We run alot of the Vortech FMU's on our mild superchargered trucks and had no failures. What kind of pump are you running with the setup?
O ya! This may solve the problem!!!!! You have way to many lines tapped off it. On the vaccum line that goes to the FMU "DO NOT HOOK UP ANY OTHER VAC LINES TO IT" . We have had a couple of cases were people hooked up a boost gauge or map sensor to the same vaccum line as the FMU and the FMU would not kick on at all or not very much. Run the FMU with its own line. Trust me on this and try it!
Old Jul 11, 2005, 05:19 PM
so RRM calls for vaccum lines: off the BOV, and intake manifold to the stock FPR. the boost controller is a closed circuit so it shouldt effect the pressure that much.
we have tested it just w/ BOV,Intake Mani, FMU running to the stock FPR and the same problem....i need to take apart the FMU to see if it broken.
Old Jul 12, 2005, 09:39 AM
bump
Old Jul 12, 2005, 10:24 AM
grubiaco's Avatar
Thanks for the advice Go.
I too had a leaking vortech FMU...
All you have to do is take off the hex screws remember where everything goes and tighten the inside hex screws. Tightening these screws will stop the fuel leak. It did for me.
Old Jul 12, 2005, 10:31 AM
Hotshot940's Avatar
how are you going to give the fmu it's own line coming from the intake manifold when you have to route like 3 other things from it as well?
Old Jul 12, 2005, 10:50 AM
sounds like an IDEA! ima check that out.
Old Jul 12, 2005, 03:05 PM
Go2fast's Avatar
Its very simple!! i routed it by itsself! There are several vaccum lines on the manifold. T into one of them for your gauge. Use the stock regulator vac line and t into it for vac. That way your stock regulator and FMU are seeing the same vac. Ill have pics of how i did mine up tomorrow. I took them at the shop today but was to busy to download them b/c of this damn Hemi turbo kit were making.
Old Jul 12, 2005, 05:37 PM
ok....kool.....yeah ill probly be takin aprat the FMU tonight....does anyone know the specs on retighting the hex nuts on the outside.....i though i herd it only like 2lbs/ft....if someone can confirm or know the answer please tell.
Old Jul 12, 2005, 06:47 PM
ok well i took the FMU arpart nothing looked outta order...it looked perfect.....so then comes the harder question.....why the hell when i mash the gas or goto postive pressure i run super lean?
Old Jul 12, 2005, 08:56 PM
Go2fast's Avatar
What fuel pump are you using???? Maybe its going bad? What FMU ratio?
What injectors are you using? Could they be Clogged? Maybe clean them
What is your fuel pressure at idle? Is it steady?
Old Jul 12, 2005, 09:40 PM
Walbro 255. 12:1 FMU ,stock injectors w/ 51000miles, fuel pressure at idle is lik24 or so....i took a video of the gauges in my car while driving...i need to edit and post them up. but im goin to check injectors....and i have another walbro 255 i can use.... but the thing w/ the injectors is the car idles fine....like 15AFR....and normal driving like 14-15AFR. but maybe when more fuel is pushed they get clogged....so im goin to take them out....hopefully this is nothing extreamyl serious.....cause my soulution to the FMU is im goin to buy a stand alone ecu and new injectors in 4months or so.
also drivng around if i go into boost and then left off in will go rich 11-12AFR but for like a sec.....when i get the video up u can see better.
Old Jul 12, 2005, 09:58 PM
grubiaco's Avatar
Out of curiosity how long do walbro fuel pumps last?
Quick Reply: Vortech FMU and you...
