Turbo kit vs. Custom kit
Old Oct 18, 2005, 06:35 PM
  #31
Evodreamer28's Avatar
whats the different between a t25 and a t28 performance wise which one is going to be better?
Comperssor Side
Garrett GT-25R Wheel Dia. Wheel Trim A/R
Max HP Rating 250HP 54.4 mm 60 . 64
Exhaust Side
Wheel Dia Wheel Trim
53mm 62
Compressor Specs
Garrett GT-28R Wheel Dia. Wheel Trim
Max HP Rating 300 60mm 60
Exhaust Side
A/R Wheel Dia. Wheel Trim
.64 53mm 62
GT-28RS
Max HP Rating 340HP
What would be ther better buy for a turbo kit a FMU FPR or Greddy emanage unit?
The simpler solution and least expensive would be the FMU. Not all FMU's are created equal so dont buy just anything. These are good quality Rising Rate FMU's that work.
http://www.cnfxperformance.com/index..._82_88_99_3020
With a Fuel pump, Fuel Pressure Regulator and E-Manage or SAFC you can get more of a fine tune for Air/Fuel but its 3 times the cost for maybe a 15 HP gain.
Old Oct 18, 2005, 07:37 PM
  #32
silkymp's Avatar
so what turbos would work with the cnfx manifold other than the 240sx t-25?
Old Oct 18, 2005, 07:44 PM
  #33
ozrally0303's Avatar
any garrett t25 and t28 im sure
Old Oct 18, 2005, 07:49 PM
  #34
The Turbo's I just listed in my previous post.
Old Oct 19, 2005, 06:53 AM
  #35
KillahB's Avatar
Originally Posted by rhyzin
you should know that there is more than one version of each. spend some time with google. i'm sure everyone in this thread knows how to use google, right?
t25, gt25r
t28, gt28r, gt28rs, big t28
20g, bastard 20g
t3, t3 super 60, t3/t04e
etc. etc. etc.
then with MHI you have the td05 or td06 housing. garrett turbos have the t25 or t3 turbine housings/flanges. then you've got bastardized/hybrid turbos.
this subject is much beyond most would want to post unless they got the time and feel like schooling you folks. google.
Couldnt have put it better myself. Sometimes doing your own homework teaches you VOLUMES more than being spoonfed all the time.
Old Oct 20, 2005, 07:22 PM
  #36
SuckaFree's Avatar
What size injectors am i going to need for about 200whp. What spark plugs hav worked well with the turbo kits so far?
Old Oct 20, 2005, 07:44 PM
  #37
maxum17ft's Avatar
stock injectors with 200whp should be fine
spark plugs are bkr7e i think, gapped to .030.
u didnt catch the google/search hint did ya?
Old Oct 20, 2005, 07:48 PM
  #38
SuckaFree's Avatar
Hell No lol
Anyway was talking to a guy and he said that a walbro 190 would work for the turbo it does anyone disagree with that but when i looked on ebaythe 190 and 255 are the same price? Which one do you guys think will work
Old Oct 20, 2005, 08:44 PM
  #39
maxum17ft's Avatar
buy the 255 walbro. you can tune it to be near perfect, and u have room to turn up the psi later on. PLUS the 255 has a WAYYYY higher resale value if u ever go to sell it.
DO NOT buy the cheaper knock off no name ones, i keep hearing nightmares about them.
the 190 would be plenty for 5psi, but for 7psi it would be at its limits when tuned correctly.
NorCal Lancer
May 21, 2012 11:10 PM
3000ways
23
Mar 9, 2006 01:12 PM
SPEED
12
Aug 12, 2005 11:21 PM
Derek888
Automotosports - Illinois
12
May 10, 2005 01:35 PM
DR_EVIL
Jun 6, 2003 03:49 PM
Quick Reply: Turbo kit vs. Custom kit
