Nitrous/Turbo Question
Old Nov 1, 2005 | 01:24 AM
Swift Drift 14's Avatar
Should I put nitrous in before putting a turbo in or after the turbo is put in? I have a turbo, just can't find the people to install it. I am going to purchase nitrous anyways, so I was wondering what others opinions are. Feel free to comment.
Old Nov 1, 2005 | 01:44 AM
Mouse's Avatar
i think you should put in the turbo first. but since you can't find anyone to install it right now, you can pick up the nos then get it all installed at once instead of going back and forth from the garage.
Old Nov 1, 2005 | 01:46 AM
N20Lancer's Avatar
I currently have a nitrous setup on my car. it definetely scares people when they pull up next to you and you hit the purge valve(Shoowsh! Cue the big cloud). I would suggest using the nitrous setup to cool your intercooler. Probably make more safe power that way. I know NX and NOS have sprayer bars(and even a weird snake bar thing).
Old Nov 1, 2005 | 09:22 AM
SLVROZ_03's Avatar
Yeah, only use the nitrous to cool the ic or for purging purposes. Our lancer's rods and nitrous don't mix well...too many a bad story!
Old Nov 1, 2005 | 12:14 PM
drucea's Avatar
wait, you have a 2005 lancer? are you doing a custom turbo then?
Old Nov 1, 2005 | 01:09 PM
Yes, I am going to get a custom install done. I have the TSI Extreme Turbo kit. The only problem the first time we tried putting it in, the fuel management system hits the firewall, needs an extension downpipe for exhaust, and heat sensor pipe needs to be cut so turbo doesn't hit the pipe. That's the only problems we have found so far. When I get the install done, I will post pictures. Same for when I get my body kit put on.
Old Nov 1, 2005 | 01:11 PM
Is there any way to get around that? Or is there any good upgraded rods that will fix that problem with the nitrous? Sorry about all the questions I'm a newcomer to nitrous. One last question: If I use the nitrous for the ic will it increase me horsepower any, if so about how much?
Old Nov 1, 2005 | 01:38 PM
SLVROZ_03's Avatar
I don't believe there are aftermarket rods, but there are pistons and rod bolts. If there are rods available, please fill us all in (BTW, I did a search). Use a 30-shot if you must. All of the people that have thrown rods have used various 50-shot setups that had a bad out come.
Old Nov 1, 2005 | 01:42 PM
SLVROZ_03's Avatar
Sorry, looked on the web and RRM has some (should have known). Here's a link to the pistons and rods they have (good quality BTW)... http://www.roadracemotorsports.com/drivetrain.htm
Old Nov 1, 2005 | 02:35 PM
drucea's Avatar
yeah rrm makes pauter rods. and buschur is selling one last set of pistons for $199 to get rid of them. and also on your turbo kit, you might have a bit of a problem with the returnless fuel system on the 05. let me know how that goes.
Old Nov 1, 2005 | 10:37 PM
What is the website or link to get those pistons? I am interested, if they still have them. The fuel system, I may have that covered not for sure what to do for modifications to that except the fuel management system I have which hits my firewall, so its useless for now.
Old Nov 1, 2005 | 10:44 PM
N20Lancer's Avatar
woah woah woah. I constantly use a 75 shot, and then a 120 on the track. a 30 shot isnt going to get you anywhere, you end up wasting your money. with proper tuning(RIP first motor) you can safely run a 75 shot. Of course, with the 120 shot i get NO traction. I also use a SAFC-II. its setup so when im at WOT the settings change and more fuel goes in! horay fuel! Just my 2 cents.
drucea's Avatar
here you go:
https://www.evolutionm.net/forums/sh...d.php?t=166360
I'd hurry up cause they say that you get a bigger discount if you want to purchase a lot of stuff to sell for more money.
Old Nov 2, 2005 | 09:30 PM
What's the SAFC-II and WOT?
Old Nov 2, 2005 | 09:34 PM
drucea's Avatar
Super Air fuel Controller i believe=SAFC and Wide Open Throttle=WOT
Quick Reply: Nitrous/Turbo Question
