Turbo + Winter = What Oil?
Originally Posted by Go_Lancer_Go
thanks n1te, that is good info, ill do that for sure...
Can n e one here help me convert Celsius temperature to Fereinheit
oC= (oF +32) * 5/9
edit* hope this helps
found a converter, we get to about -25 F in peak winter
-25F holy crap!! are you sure? you would need to Ski to work if it was that cold. the lovely 4g94 wouldnt cut it
no wonder you guys need block heaters! Today it's about 29 F outside and I hate it. There's no way in hell I'd live in Canada. If I could convince the wife, I'd move down south. Winter sucks.
-35? Isn't that passed the point of coagulation? You should have a block heater if that is the case... In NY, I run cheap organic 5w30 in the winter and 10w30 in the summer. I am not a fan of synthetic in these engines, I do however use synthetic in my Audi (Amsoil). DO NOT request organic at your dealer, they may quickly void your warranty as you are taking the car out of factory spec.
Like many have said, sufficient warmup is good for all your moving parts.
I called RRM and asked, and they told me to use 10w/40... that is for our Michigan cold winters. In the summer, they tell me to use 20w/50. I just got my kit installed today and it runs freaking awesome.. hahahahah. If only you could have seen the expression on my face when I downshifted into 4th gear on the highway and hit boost... LOLOLOL omfg.
^--yea, it needs to be cleaned up a bit..
organic....i remember hearing bad things who ran synthetic with the rrm kits....im running 20w50 all year round so far....havent noticed nay problems but to be honest i dont know what kind of problems to look for
20w50 in summer. Go to 10w40 if you like in winter. That should do the trick. I know we don't know **** about cold .... it is about 75 degrees right now as I write this.
ROAD/RACE
ROAD/RACE
