Water/Meth Kit
Water/Meth Kit
Has anybody even thought of that yet. It's pretty inexpensive and yields great results. Lowers egt temp. by alot.
I know that alot of dsm's are using it.
What do you think?
What do you think?
you can run a 50/50mix water/meth it works great. get a boost switch so as soon as you hit 4psi it starts to spray.the meth will raise octane and the water will help cool the charge.u can use this and add a little timing or up the boost a psi or two
its a waste if you cant increase timing or boost. At only 7-10psi on a t28-16g your not making any real heat and a decent ebay core will be able to cool that. So until you can run a decent amount of boost, its not worth it.
coolingmist. i did a run with meth and my a/f were about 11.3 across the board i turned the meth off and it leaned out to 12.1 which is still safe there r fail safes that u can buy if you run out or a pump fails
water/meth injection would be great for pretty much anyy turbocharged car. As said before, even lower temps, higher octane etc. will allow you to run a psi or 2 higher on our cars, with adding some timing and cooling the intake temp it would yield some good power.
