Sandwich Adapter for turbo feed....
Searched and searched on several forums and everyone has different opinions on what works best for a turbo feed/return... So everyone seems to agree that the inlet feed for the turbo should be pressurized. And that the return side should not be pressurized. so i got to thinking... wouldn't an ideal location be one in which oil is constantly pushed thru the feed and pulled out the return? forcing the turbine to get constant oil circulation??
So i was thinking and our oil filter has that exact situation. Refering to the attached picture which has a dedicated inlet/outlet, couldn't I use this filter relocation kit and just connect the turbo feed/return in one of the lines? Connecting the feed/return inline would create a situation in which one side gets positive pressure and the other side sees negative correct? I dunno if anyone thought of doing this before but I just wanted to throw the idea out there....... So if anyone can chime in on this theory please I woul really appreciate it. Thanks
Im saying that you only use one of the lines. Adapter "out">>>"turbo in">>>turbo out">>>Relocated oil filter IN. Then Relocated oil filter OUT>>>Adapter "IN"... So the turbo feed/ return is actually spliced into only one of the lines. Thus only one side will see positive pressure..
That's the way it's been done since people started turboing the lancers. Theres already a port above the oil filter. Then gravity pulls it down into the oil pan (the upper part). The only reason you wouldn't do this is if you used a remote mount turbo, where the turbo would be inline with the exhaust, thus being lower than the oil pan, calling for some sort of pump to pull the oil from the turbo through the line and upwards back into the oil supply. STS systems use a pump for this.
marcouxa1
Lancer Aftermarket Forced Induction Tech
28
Nov 5, 2023 05:28 PM
WW-GSR
Jul 6, 2012 12:32 PM
TheLab
14
Oct 13, 2007 10:58 AM
