Castrol GTX for RRM turbo app...
True. But thicker oil also ensures proper lubrication to the engine after the oil has thinned out from also lubricating a hot turbo. The 4G94 oil pan is ill-designed and doesn't maintain good pressure on oil that's too thin from adding a turbo. An oil cooler is a good addition to any setup and aids in keeping the temps down and pressure up.
Hmmmm.... I guess this whole oil argument really depends on where you live.... Read the chart in your manual for the specs on different recommended ?W-?? Colder temps usually use 0W or 5W but those same ones are also used in normal temperatures in which a thinner oil is recommended to increase fuel economy. So a 0w-50 will be thinner than a 20w-50 at startup(which shouldn't really be a problem)
I changed my oil yesterday and switched over to a 15W40 to see how it would affect pressure. My oil pressure dropped about 5psi at running temp and now sits around 10-12psi. This is still within spec to the Mitsu service manual which says pressure needs to be above 3-4psi at idle, IIRC.
After I drop in my new engine I'll be running 0W50. I don't think we can run anything thinner than 40 and still have adequate oil pressure. I wish someone could figure out what the design issue is with the 4G94 oil pump that prevents it from working well with thinner oils.
