RRM Turbo installed/completed
#271
any huw just post the video here so everyone can see it!!!
one other thing can any one explain tome what is an open deck and a close deck when referring to turbo and NA settings!>?
#272
^^ very true..serious if its anyone who dosent know a lot about the car its you man.
you were the one that made the post "oh well i can just buy evo X internals and turn up the boost and this car will be fast!"
everyone called you out on that one that you didnt do the proper research or that you didnt know that its more than just internals for the car..also that you really cant even use the evo X internals..its much more than just swapping those if you want to push power which you seem to didnt know until everyone else said something about it.
4B11 compared to 4B11T
#277
im not ashamed to admit. this place can suck some serious *** sometimes.
no pun intended for Serious08
I take requests from this place very lightly. I know i know..complete @$$hole....ah well
vrooooooooooooooooooooooom psh
#279
My reference wasn't pointing out that I know everything about turbos or the car. It was pointing out that those of you that are bagging the kit have never installed a turbo and/or done the tuning in an 08 Lancer. Until then, you have no idea. Only Rob and Brian know what it takes to accomplish this. I don't know what it takes, I just know know how to install one on the 08/09 Lancers.
And yes Luda, evo x internals will work. Does it mean its a direct swap or plug-n-play??? Of course not. Doesn't mean they won't work.
But whatever. You seem to be king douch around here so continue talking out your douch nozzle and critizing a kit you have absolutely no experience with.
The offer still stands for you to bring up which ever car you want (Evo, GTS, Si) to Ft Worth for a "fun run" and first hand look at the kit.
#281
im not being a douche as said before i dont have to have the kit to know about it..this turbo kit isnt a one of a kind never before seen kind of thing like your making it seem. i dont know why your big and bad calling out people to come up to race you when it would be a waste of time..you called out an IS350 or 250 whatever which is obviously out of your league, same with an evo.. you should be challenging cars more in your league no offense more like a turbo TC or a Bolt on Si,Ralliart, MS3 things along those lines..
#282
are you talking to me?? actually you can put evo x internals in the 4B11...they DO fit. also, i never said I could do that. thats why i started a thread asking the difference between the 4B11 and 4B11T, and asked what I would have to do to turn up the boost. that being said, absolutely no one "called me out," they just said it couldnt be done because of the block. that thread was my research, so I had no prior knowledge about turning up the boost, and once the people had responded, I was informed. Also, i knew that swapping internals wasnt the only thing I would need to do....again, thats why i started that thread!!!!
Actually I already looked into that and you wont be able to transplant 4b11t internals into the 4b11. You would have to just do a complete swap if you want to up the boost. Compression ratios on the two blocks are entirely different. If you want to up the boost you'll need to either do a 4b11t swap or find a shop that will custom forge them... It sucks
Just keep your fingers crossed that a tuning company will pick up the lancer.
#283
evo x internals will work..but the compression is way differnt thanwhat you need since evos come much more boosted than the 6-7psi your running..same with why lancer owners right now wouldnt benifit from evo x internals..compression..and even if you did get the internals..theres lots more things that you would have to upgrade..that currently no aftermarket companies support.. which was kinda argument in the other thread on why the lancer isnt a racecar.
#284
You need to keep your head straight on your shoulders, all Luda is trying to do is inject a little realism into you. IS350's are out of your league, on paper and on pavement. You are shooting way to high for the actual capability of your car. And stop street racing... 20/40/60mph rolls are literally the worst way to compare your car to others. HONK, HONK, GO HONK!.... One car will always get the jump on the other. take it to a track and race it from 0mph and don't forget to heat the tires. With out a LSD a bolt-on Si will get the jump on you and from there it is a toss up.
for the last time people the X's internals won't work... If you honestly believe they will than try it. It's not my car you will be destroying.
#285
"The offer still stands for you to bring up which ever car you want (Evo, GTS, Si) to Ft Worth for a "fun run" and first hand look at the kit."
