List of Turboed Lancers
Ok so i figured we should start a list of everyone on here that has a turboed lancer.
Maybe we could separate it by custom install - 16g
other turbo
rrm kit
This way we get to know whose got what and if we ever need to ask any questions then the list is right here.
Once ur name is on the list, and u send me a dyno sheet, ill update with ur HP and torqe.
and have a link to ur build thread if u have one
16g custom install:
zulu989 ---------- 182 whp / 190 trq 7 psi
Link62 ---------- coming soon
JRR ------------ 11 psi
Boostedlancer$ ---------- 313hp / 326 trq 19 psi
ThunderOZ --------- ?
sawulkn ---------- ?
03lances ---------- coming soon
lancerEVA06 --------- ? 9 psi
Incrphish ------------?
lilazn64 -------------- ?
oz rally ------------- 10 psi
*02lancer* ---------201 hp and 187 hp 6 psi
RRM:
4g94T ---------------------216 hp / 278 trq 14 psi
lancerguy'03 -------------185 hp / 210 trq 7 psi
t3lancer2003 ------------- ?
Green_bandit ------------ t 28
Custom:
depsy ----------------235 whp / 233 trq (aem ems tuned also @ 10psi)
cincy --------------------- gt28r 190-200 whp 7 psi
Demon ni2 ------------- garrett 60 trim t3/to4e 197 hp / 180trq 5 psi
puerto reCOn
brutus.nova
blah blah blah so send ur infooooo
other turbo
rrm kit
16g custom install:
RRM:
Custom:
puerto reCOn
brutus.nova
josh here-
evo 3 big 16g
wrx440's
501 maf
rrm mani (due to the turbo)
basically all evo from there
evoscan and ecuflash tune
rrm full ported intake side (im, tb, and rail)
evo 3 big 16g
wrx440's
501 maf
I have a 02 lancer with a custom evo 9 16g on it fully built top to bottom. right now on 19lbs of boost i made 313hp and 326 ftlbs of torque. the reason i didnt make more power is that i didnt know that i had to degree my new 272 intake and exhaust cam with adjustable gear. once i degree that and adjust the timing i should be in the high 300's but thats all for this season it almost winter here.
1 Post
Murphy(sawulkn) is running close to the same setup as me:
Evo 8 16g, evo piping, 12:1 fmu, megan mani with 4g94 flanged welded to it, megan o2, walbro 255.
I'm also running 8psi, using an evo 9 bov, hks intake and will soon add wrx 440cc injectors
1 Post
TDO5-16G, E85, Evo 8 ECU, 550cc injectors, walbro 255 (still on returnless fuel system). No clue on horse power numbers, but running 9psi boost, and 10:1 AFRs (tuned strictly for E85)
im trying to get pocket dyno on my ipod to work annd get some rough numbers. unfortunatley no time aor money to actually got and get it dynoed.
o and an fyi im at 11psi as of now with the greddy profec b spec 2 boost controller
josh
josh
This is Virtual Dyno Room.
There is an evoM correction factor that everyone on evoM uses to compare numbers.
Those that use mitsulogger or evoscan can copy / paste their logs onto this excel spread sheet. Just input the weight, gear ratio, occupant weight, and tire size.
