air leaking from Turbo Seal?
First, I have the RRM T28 turbo kit. I have a leak in the area that I pointed out in the picture, I think thats between a seal and the housing not sure. But You can kind of see a gap there. It's bad enuff to make smoke come out the tailpipe and it leaves the front of my crank case black with smoke. It accelerates poorly, loud tapping noise like a diesel truck when I accelerate.
My question is... Can I just get it welded shut? The shop that would be able to fix the leak is plannin to take off the turbo and do a rebuild. Which they are chargin me a sh..load for labor. I found this online, I think this is what can fix it? Then again I would need the shop to install it, and they chargin for the labor.
http://www.gpopshop.com/garrettt2kits.html
to have a gap there would mean one or more bolts r loose.. you might need to remove the turbo to reach the 1 or 2 bolts u cant see in the pictures to tighten them.
can u just weld it? No.
does the turbo need to be built? um.. if that one leak is all the problem, then no it doesnt need to be rebuilt.. if its a RRM kit u purchased, then that turbo is brand new..
has anyone else had this problem with the bolts on the hotside of the turbo? all those r for are loosening the hotside so you have clock the turbo any direction you want, i would assume that a couple of the bolts have worked there way loose.
where does that piece from the intake, like the silver part that parts off into two outlets. where does the smaller outlet go to? I know where the intake goes to
we occasionally(daily) get very newb questions that i think ponder the question, 'how did, err, why did, err.. wth? and you have a turbo on your lancer? and you dont know basic mechanical stuff'
not trying to poke fun, its a daily thing out of many many different people.. basic mechanical knowledge and not being scared to break something is how you learn..
start by tightening the bolts.. if u cant reach them all, then u will have to take the turbo off and tighten them then put the turbo back on.. if your scared to do that, then i think u should find another hobby. (i mean, i hate to hear people say i spend x amount of dollars at the mechanic shop just to fix something small and stupid) and it always happens..
if that does fix the problem, well you will need to take the turbo off either way and examine it further. u should be able to dissasemble it completely yourself with basic tools.
if your only feeling air in that area, and arent 1000000% sure its coming from there, it could be the gasket that goes between the turbo and the turbo manifold flange that needs to be replaced(more likely the culprit if your not 100% sure its coming from that specific place on the turbo)
ok well forget the question I posted on top.
Ok so I installed the stainless steel housing on my turbo well on of the bolts got F***** up so I have only four, the fifth bolt is on the outside where the housing comes to a point like above the pipe thats coming down. Will I be fine with four bolts on there or do i need all five. I'm nervous about loosing boost if it won't seal.
I'm having some guy drill into the bolt and put a smaller one in with two nuts on the side to sqeeze it in place so I hope that helps... any help on what should I do?
I tried tightening the bolts and still no go. I believe I might have to dissasemble it. And demon is right. I didn't expect all sorts of problems when turboed. If i could go back and fix my mistakes I would. But for now I have to get this crap fixed so i can drive my own car to work
High_PSI
119
Oct 4, 2016 08:20 AM
BigDaveDogg
28
Mar 9, 2015 09:54 PM
quinn6051
Oct 19, 2010 09:12 AM
