TDO5HR Wastegate Actuator for 5-9 psi?
Hey guys, I just picked up my turbo & turbo manifold for my 4g94T build. The turbo is a TDO5HR, it did not come with a wastegate actuator, and I am looking to purchase one that is suitable for my 5-9psi that I will be running for the build. If you have any info or links to an actuator that will work please post!
I'm assuming: http://www.maperformance.com/forge-a...-evo-viii.html
with the 5-10 psi spring option correct?
mitsubishiparts.net or yur local mitsu dealer. just tell them the turbo is off an 8 and they should know what ti get. i have the numbers somewhere but ill have to look.
josh
josh
here is for the coolant lines:
FEED MN143305
RETURN MD363253
eylet bolts for above coolant lines
EYEBOLTS MF650114 (need 2)
WASHERS MF660065 (need 4)
oil return gasket
TURBO SIDE GASKET MD194403
i cant seem to find the oil lines but thats what i have.
josh
FEED MN143305
RETURN MD363253
oil return gasket
josh
boomtown
83
Feb 2, 2022 03:58 PM
sphynx
15
Jul 25, 2011 09:27 PM
