Mitsu.kid.kid's Turbo thread!
#136
http://www.youtube.com/watch?v=XVqURki98KQ
-my buddy hookin it up to get towed to my house after the oil feed line burst
Today was an intersesting day....so turbo is on and all is good. My buddy flips his spec-v earlyer, completly totalled, then the oil feed line got a small hole in it from hitting the manifold wich threw oil all over and caught fire...i was able to put it out and the car is running sweet again :-) So aside from the small engine fire everything is good!! one question for you boosted guys tho.. when i let off the throttle, even not in boost, the car runs way lean...like the wide band wont even read it..it does the
"---" thing on the gauge, then when i apply throttle again it reads, is this normal? At idle its about 14.4-15.2 and while crusing anywhere from 11.5-15.1 depending on the load etc. In boost it reads 12.3-13.4 so i have some tuning to do
#140
awesome man!! congrats
if you dont get that other stuff soon, ill mail it out personally for you...ill be home in a couple weeks...tread lightly till then!!
turbo'd my lancer [X]
tour in iraq [X]
take over the world [in progress]
lemme know if you got any other questions or concerns
tour in iraq [X]
#141
tour in iraq [X]
tour in iraq [X]
Its awesome having this done!! Its really just so addicting i wanna drive everywhere, the car just sounds different even at an idle, its sweet!
Yeah, well i hav an auto trans, so i can really put it in neutral or anything, but if its normal thats fine then! Just have to work on tuning so the wideband reads more richer when in boost, and im only getting to 3 PSI, so i must have a leak somewhere in the system.
#142
Hey guys got some questions!
Ok, i got the 5-10 Spring rite now, im only hitting 3 LBS of boost no higher.
Would any of these things cause it not to reach the full 5? Is the wastegate spring adjustable?
-On the evo intake, the nipple that is suppost to connect to the valve cover i have unplugged
-On the evo8 BOV i only have the vac line zip-tied on (i dont want to snap the plastic nipple with a clamp!)
-I have the vac from the forge WGA connected to the evo 8 j-pipe
#144
and technically you would hit about 4.5 psi of boost until you mess with the w/g (not totally sure how this adjustable one works). i dont deal much with internal gates, i think they suck personally...
josh
#146
And as far as leak problem i would agree with JRR everything needs to b covered any lil hole that air is coming out automatic leak n car wont run rite also chek all ur bolts makes sure all tight as can be and my vac lines are all mostly zip tied as well and are all good also more vidsssss lol and picsss lol thanks
#148
First of congratsss once again n men that fire thing sounds crazy like nightmare lol always thought that would happen to me but yea ur good on wideband going lean when letting go all good there quick question tho when you first turn on your car and u start driving does you wideband read a rich until like car kinda warms up then wideband goes to like 14.7 thats what mine does but ive been told RRM piggy n 5th inj setup makes car run super rich
The fire was deff scary dood, my whole car filled with black smoke cuz i had the vents all open good to laugh about it now ya kno? Well when i first start the car ya it reads rich then when it warms up it eventually gets to 14.2 or so! But ya man im lovin this boost!! ill double check all my connections, i wanna get close to 5!
Also whats considered dangerously lean while in boost? like an AFR range
#150
home made Boost leak tester- http://www.vfaq.com/mods/ICtester.html Is the turbo outlet on the compressor side of a 16G turbo 2.5''? Ima go make this today
