Mitsu.kid.kid's Turbo thread!
#77
So i got my AEM wideband, 10'' Slim Fan, NGK plugs! Now that i got all the big money items out of the way, All im waiting to get is!:
-Evo8 J-pipe, because the 9 didnt fit
-Trans Cooler will be here 09/02/10 Any advise for mounting places??
-4 feet of -4AN steel braided oil feed line
-3/8NPT to 5/8 barb for the oil return
-5/8 heater hose
-Electric fan mounting kit
-Coolant
-10W30 Oil with new oil filter
-RTV High-temp gasket maker for the pan
-T-bolt clamps (how many should i get?)
-Zip ties
-Vac lines
-Tools
Am i missing anything else? i really want to have everything handy right there when im doin the install! Is the electric fan mounting kit just like big zip ties? They go through the fins on the rad?
-5/8 heater hose
-Coolant
-Zip ties
-Vac lines
-Tools
#78
well if u want i could get u a oil feed line made with hydrolic line, its what im using bc my steel braided line broke?
and yes the fan kit is like 4 bucks and just is like 4 zip ties lol
#79
-5/8 heater hose
-Coolant
-Zip ties
-Vac lines
-Tools
-5/8 heater hose
-Coolant
-Zip ties
-Vac lines
-Tools
Why not go with 5w30, it's what the manufacturer recommends.
Did you say where or how you're connecting your oil feed, I can't remember. Sandwich or hex bolt?
#81
I got these tbolts, a kit: http://www.siliconeintakes.com/produ...roducts_id=311
PM'd
#83
bro its 10w-30, I heard you dont want to go to thin, right now thats what im running valvoline 10w-30 and I havent had a problem with heat at all.
#84
i ran 5w30 straight castrol gtx the entire time. oil is oil. its lack of oil that kills ya.....
i know that the evos run 5w30. and you only need 4.5 qts to fill the entire system, even with the turbo...
#85
i break motors in on mobil1 5w30.. and ill use nothing but amsoil RD-30 on my car. can not sacrific your oil choice, when your pushing your car like we do!
#86
please use full synthetic not convential, or turbo death will be what kills ur turbo setup (and technically its 3.8 qts to fill the system, plus a little extra for the turbo feed line with isnt much at all)
5w-30? JRR hmmm Im told so many different things im not sure whats right anymore, I remember when rrm told me to use 20w-30 oil last time...
#87
i changed mine every 2500-3k anyway and spent the money on good filters. i run even the same oil in my rex. never had a problem. as long as you dont use like a penzoil or a quaker state which actually leaves a film on everything, castrol does not which is nice.
like i said earlier tho to is that lack of oil is gonna kill you, not by what oil you run....
#88
tell that to the people over on nasioc..lol. every other week i find another thread that mobil one blew up my engine......(now i dont know all the circimstances tho) but over there mobil one is like an evo, its all bad news....
#89
In my car now i have been doing oil changes every 2,800 miles with 10w30 castrol GTX conventional motor oil. Should i stay with the conventional oil, or use synthetic? Im not going to be constantly driving in boost, or run down the track every weekend. I have heard alot too, about conventional and synthetic and whether to switch or not, but im still unsure. I want to be as safe as possible, i have 134k on the odo, car runs sweet no problems, but still want to be as safe as i can!
#90
QUESTIONS WITH PICTURES:
1.) IN THIS PICTURE WHICH DO I USE AS A COOLANT RETURN/ FEED?
2.) DOES THIS PICTURE LOOK CORRECT? I FIGURED THE RETURN IS OBV, I FIGURED THE OIL FEED PORT ON THE TURBO (SHOWN BLUE) IS THREADED, WHICH WOULD CONNECT TO THE -4AN LINE. THE WATER LINES ARE NEXT TO EACHOTHER AND BOTH HAVE A BARB FITTING COMMING OFF THE TURBO, SO I FIGURED THOSE WERE THE WATER LINES. (ONE BLUE AND THE OTHER SILVER). WHAT COOLANT PORT IS FEED/RETURN?.
