Idle VAC in/hg
Idle VAC in/hg
Hey, what are you guys reading at idle in vac? Isnt it suppost to be like 20? i just got some new gauges and mine at idle is sitting at about 17-18 or so.. is this a normal reading, or do i have a Vac leak maybe?? What are you other guys readin?
-Tony
-Tony
mine reads......22 i think, maybe 21. You should do a boost leak check if you even suspect you have one....and even if you don't, because lets face it, easy problem to fix and it causes all sorts of crazy hard to trace problems.
The manual that senate posted has the required vacuum setting i think, that's where i saw it i think...not sure for sure though.
