Who Is Running The Most Boost?
Old Dec 15, 2003, 01:54 PM
Guru_Del's Avatar
Originally posted by JVlancer
i run 7-8 psi daily.. guru.. how did u lose to a ralli art????
it was an RRM ralliart. they had their go fast goodies on it and it was pretty damn close, i think i lost cause i fell asleep at the launch.
5 psi for now 7 in a week or so
Old Dec 15, 2003, 01:56 PM
IgotaWhiteOne's Avatar
i turned mine up to 20 daily driving heh just in case someone messes with me. Heh i bet yall just wanted regular lancers just tellin u mine
Old Dec 15, 2003, 02:09 PM
mobius97's Avatar
I wanna run at 20 too!!!!! Damn time to go get some 550's!!!!!!
Old Dec 15, 2003, 02:54 PM
TURBOit's Avatar
running the stock like 5.5 psi, an intercooler would be quite nice to run 7 daily considering i have the pistons
Old Dec 15, 2003, 03:36 PM
bahamut's Avatar
HK,
It will take a lot of fuel management and tuning to get 20 psi on 9:1 CR, on the very edge. IMO, the lancer needs to drop CR to the level of DSM.
Look at the DSM from 8.5 to 8.7:1 CR, they can crank +20 psi.
Old Dec 15, 2003, 08:47 PM
omarboy25's Avatar
I am running 7psi and waiting to go faster!
have je pistons, motor mounts, rrm lsd, and
connecting rods on the way as well as stronger
head bolts and stronger valves. port and polish
on cylinder head on the way! oh yea
Old Dec 15, 2003, 09:01 PM
eldanoloco's Avatar
Originally posted by HobieKopek
If I can find a solution to my fuel problem, expect relatively high boost from me in the spring/summer.
Running 20psi would probably take less engine work than you think. Decompress to 9.0:1, forged pistons and connecting rods, possible knife edged crank (dunno if that's necessary, but I believe it probably would be at that level), a P&P on the head and a new valve train. Viola! Basically as long as there's fuel, there is boost. Obviously you'd need a new clutch. And you may run into problems with exploding axels at some point along the line, but nobody really knows right now. At any rate, I plan on running around 1 bar daily when I get my car back together and get to the root of my fuel delivery problem.
I doubt knife-edgeing would be necessary, its just to reduce rotating mass. New valve train would be good if you had to rev past redline and I'm not sure about the port and polish. But you hit on the head with axles, the HP number associated with 20 PSI is going turn those axles to shrapnel.
Old Dec 15, 2003, 09:02 PM
eldanoloco's Avatar
Hey lend me some money and some energy cuz you have to much of both.
Old Dec 16, 2003, 07:27 AM
HobieKopek's Avatar
In order to more fficiently spool a turbine at 20psi it's going to take a bit more revs and a good bit more breathing than the Lancer provides in stock form.
Old Dec 19, 2003, 06:08 PM
Jayz-1's Avatar
My mate is running over 30psi (Gauge only goes to 30psi) on his 1.8lt SOHC lancer with a huge turbo.
It even fri's the tyres in 5th with 293kw at the wheelshttp://www.fullboost.com.au/racing/r..._4cyl_fwd.html
He is the 12 or somthing fastest in Australia.
Jason
Old Dec 19, 2003, 11:12 PM
tenkawa_akito's Avatar
his smaller engine probably revs higher and faster than the 2.0l lancers we have. The head needs to be ported and polished on our lancers to make them breath properly. a low flow head will hamper any turbo plan, no matter what. also, a change of cam profile will help out too.
Old Dec 19, 2003, 11:20 PM
omarboy25's Avatar
wouldnt the cams raise the temperature as well especially with turbo set up thats what i heard im not sure if i should bother with the rpw cam stay posted more boost on my lancer by late january
Old Dec 22, 2003, 07:19 AM
HobieKopek's Avatar
Yes, retarding timing can raise exhaust and underhood temps, but I'm not certain I see what your concern is exactly.
Old Dec 22, 2003, 07:40 AM
Link286XT's Avatar
i should be able to push 14psi, but i would need a new turbo, the tdo4 maxes out at 11psi. oh well soon to be upgraded!
bafhoops89
Jan 27, 2012 01:29 PM
racer135
May 5, 2009 02:13 PM
80210
May 26, 2007 02:15 PM
SlowCar
34
Mar 2, 2007 11:55 AM
EvoDaWayToGo
13
Apr 9, 2003 10:33 AM
Quick Reply: Who Is Running The Most Boost?
