Who Is Running The Most Boost?
Just curious to how much boost everyone is running. Who is running the most. How much? Any problems?
Will be boosting soon- have to break in the new JE's
i run a little over 8 psi ( its in bar so i cant remember what it is exactly) with no pistons, its fun cant wait till i get to turn it up when i get some internals. but you know road race is turnin lots of boost on that drag car, i thinks its at least 12 but they have the pistons
jeff from mlc is pushing 16.5 or 19.5 psi..i forgot which one im thinking it's 16.5..but either way it's up there. he has his engine bored to a 2.5L engine with drag pistons and rods in. yea, true fun there.
Originally posted by Drive02Lancer
heh, i'd like to see the first Lancer to push 20psi...just like the Evo...that'd take a lot of engine work though. but would still be cool!! and wuts up with ppl sayign the ralliart 5spd beats turbo lancers...is this true?? if it is...that blows
I am sure it would be close, i am gonna be running 6 or 7 psi soon.
i'm running 9 psi daily and as soon as the weather lets me, i'll be putting a new actuator on that'll put me up to 12 or 14. but then again, i'm not driving a lancer
If I can find a solution to my fuel problem, expect relatively high boost from me in the spring/summer.
Running 20psi would probably take less engine work than you think. Decompress to 9.0:1, forged pistons and connecting rods, possible knife edged crank (dunno if that's necessary, but I believe it probably would be at that level), a P&P on the head and a new valve train. Viola! Basically as long as there's fuel, there is boost. Obviously you'd need a new clutch. And you may run into problems with exploding axels at some point along the line, but nobody really knows right now. At any rate, I plan on running around 1 bar daily when I get my car back together and get to the root of my fuel delivery problem.
Originally posted by initialDRacer
Offtopic: How much did it run you total for new clutch install including labor?? Did you use the one from roadrace or something else?
Clutch and pressure plate w/ TO bearing and alignment were $425 shipped. Labor from BM Tranny was something like $250-$275 if I remember correctly. Took about 2 hours and it would have gone faster if the day wasn't so busy and Keith wasn't such a bum. (j/p) It was only the second Lancer clutch they'd replaced and disconnecting the axel from the suspension took a bit of time and effort. It's an install I could definitely do myself, but wouldn't advise unless you can get your car a good bit off the ground. You definitely need room to work.
Anyway, I'm glad I did it then even if the clutch was a bit of overkill (it's still fine daily driving, just a bit crunchy on low RPM launches) because it's only less thing I'll have to worry about as I continue to build my car. ...Or one more thing with my luck.
