Full Evo conversion
Its damn expensive... but its possible. The engine will drop right in, and the transmission and awd will work too. However bear in mind that it will again cost a lot and will take a good few days to sort out properly (thats if everything fits). Oh and u will need an evo x fuel tank as the regular lancers block the AWD tunnel already built into the car.
the evo rear end/underside and lancer rear end/underside is not anywhere near the same..
even the suspension pickup points sit around 6inch higher in the evo chassis compared to the lancer.
please dont spread miss information unless you can confirm first hand.
if you cant afford an evo at least at minimum start with a ralliart, that the cloest you'll get. the ony thing you miss out on is the S-AWC but the AWD in the ralliart with some good tires is an amazing machine, you already have the evo X motor and what not.
As they all stated, go ralliart. If insurance is what worries you try progressive. I remember hearing they don't recognize the ralliart as an awd monster and more of a compact daily driver. Meaning the insurance will be very low
Rhev
20
Jun 11, 2013 09:32 PM
ZWingerRyRy
Feb 19, 2009 03:24 PM
BlackS130Zturbo
25
Feb 21, 2007 09:29 AM
2002, calilancers, conversion, es, evo, full, gts, kit, lancer, mitsubishi, rear, rwd, sale, subframe, swap
