turbo lancer dyno results
#31
Okay, I was just trying to put it into layman's terms... and I went a bit over... misread the easy drivability at high boost as, easier to have high boost. My apologies.
As for JR, could we just safely say that they're biased, triple diamond hating a-holes?
sidenote: my last name just happens to be the same as romeo, and are you referring to T-Money from the American Gladiator's-esque Battle Dome, who also appeared briefly in Training Day?
#33
I was just trying to put a light spin on JR's business practice. I don't think it's anything personal against Mitsu, of course.
Though, I find it strange that they don't even cater to the non-turbo Eclipse/Talon crowd. Even companies that are usually exclusively for another set of car manufacturers cater to them. Like Stillen for instance that only really does Nissan and Toyota/Lexus otherwise. Just kind of strange, is all.
#34
Little late to reply
IF what I'm reading is correct through emails to ROB and reading the forum, the Road Race turbo is COMPLETE (nothing else to add), but the RPW kit has to add a computer and possibly some other stuff. Am I correct in this?
#35
The only thing you need in the RPW kit is the intercooler piping and an intercooler (if you run more then like 6 psi). The only reason I needed more stuff was because I bought mine for a mirage from RPW before a turbo kit was rarely talked about for the OZ being reality. So now they have a 95% complete kit.
#36
BARSE YOU ARE CORRECT!!!
ROAD/RACE Turbo kit is complete... COMPLETE. Don't underestimate the difficulty of completing a kit yourself or tuning. Dyno time ain't cheap. Our basic kit will not require you to tune it. Some kits require a lot of stuff that they do not incclude in the price. As for extra piping, we give you all the piping. We even powder coat piping for you as well. Some kits come with no piping. All piping means= no extra piping needed for external wastegate. No piping= No piping. Zlancer paid about $800 for piping.
ROAD/RACE
http://www.roadracemotorsports.com/
ROAD/RACE
#40
$3800 with intercooler, $33 without. Might go down in price later but hard to tell. The price is not bad considering you just install it. No trips to muffler shop, dyno, parts store, intercooler store, painter. You don't have to weld anything, cut anything, paint anything, get anything, tune anything, drill anything, wrap anything......
ROAD/RACE
ROAD/RACE
#41
1 Post
The RPW turbo kit is supplied with everything including dump pipe to cat converter, injectors, internal wastegate, blow off valve, oil and water lines (Teflon coated rose joint hoses), rising fuel pressure regulator unit, thermo fans, turbo manifold, Garret GT-28 ball bearing turbo (Rated to 350hp).
The items not supplied are the intercooler and associated intercooler piping and computer which are items that you can readily source by your chosen fitter.
This way our kit comes standard at 5 psi for those who do not want to fit an intercooler or 7 psi for those that do.
Our kits are always available at any time and we can put it together within 1 week of ordering subject to sales this week.
Our kits are sent worldwide - we just finished sending off two mroe kits this week one for a Mivec Lancer in West Indies and another turbo kit to a Lancer in India.
With the Lancer now available with the 2.0 in Australia we will also be doing more research on the lancer with even more options on the turbo gear including the turbo grind camshafts etc.
David Thomas
www.rpw.com.au
David Thomas
www.rpw.com.au
