2011 Lancer ES - Turbo?
I just got a lancer ES Turbo And Believe me i got a steal on it compared to any other version of the lancers got it brand new for 13.8 with tinted windows, now i have been slowly upgrading it since i got it about 2 months ago, i have been looking into puting a turbo into this car, but i want to build it custom piece by piece over time because the kit by RRM is overpriced underpowered and will not smog in california, which is a waste of time for me but if i am able to use an X turbo or a RA turbo than this will smog, get enough power, and if put together slowly save me some money, no i made a post of this before but someone told me to just look around, well i have been for a few weeks now and no one is giving any kind of direct answer in any forum if this is possible and if it is i would need the parts necessary and if known the actual part #s
i appreciate anyones help in this and please no answers to just redirect me to another thread that doesnt answer my specific questions
thank you
thank you
so you got a lancer ES Turbo, and want to turbo a turboed car? what? you dont have any specific questions. look around all the threads on here, theres a lot of information. Also, if you dont even know what parts you need to turbocharge a car, dont turbocharge a car.
well sorry i guess im not specific enough but it is not a turboed car i want to turbo it but want to know what i need specifically i want the power of a turbo in my car and want to slowly build it piece by piece sorry if im wasting your time
well i lack the knowledge but im going to be having my mechanic put these things in i just want to find each piece and make a kit myself, it just seems like all the kits out there are very expensive and not that great from what i see i need
-turbo
-intercooler
-oil cooling lines
-manifold
-intake
i know theres more but my problem is i dont have part #s and i dont know how to find stock part #s after i had been looking so long
-turbo
-intercooler
-oil cooling lines
-manifold
-intake
you dont need part numbers. thats the point. there is no "number" for a turbo kit. you need to know what you need to turbocharge it correctly, and then find that stuff for sale on the forums (since you want to save money). You should go online and do research on turbochargers and turbo kits before attempting (or having your mechanic attempt) this install.
Gotcha I see what your saying now. Well in the past 2 days I reqd that the ralliart turbo set up works fine and I see alot of ppl selling them for a good price because there upgrading so maybe that is my alternative
Turbo
Exhaust manifold
Collector pipe
Downpipe
Front mount intercooler
Lower intercooler pipe
Upper intercooler pipe
Oil pan bung( to connect oil line to turbo)
Oil return line(oem wont work for what ive heard)
Coolant lines
Coolant fitting or coupler( to coonect coolant lines to turbo)
Blow off valve (got 2 fs)
Evo x or ra intake or custom sri with recirculated bung
Wastegate
Tune
PATIENCE lmao
Hope that help
Exhaust manifold
Collector pipe
Downpipe
Coolant lines
Wastegate
Tune
PATIENCE lmao
Hope that help
I tou i had the whole thing i was just missing fittings and lil **** like hoses well those lil stuff cost me about $300 so u do need a lot of patience nd $$$ also i forgot to metion u will need an intake ,either evox or ra oem or a sri cuz ours wont work because is missing the fitting to recirculate the bov
When building turbo car you cannot get following three things together.
Cheap, Fast, and Safe
Cheap+Fast=Unsafe
Safe+Fast = Not cheap
Cheap+safe= Not Fast
My .02 is do your research and dont be cheap when it comes to parts.
Cheap+Fast=Unsafe
Hi
I had a 2012 SE and i wanted to put in a turbo and EVERYONE told me not to because :
it's front wheel drive and they are not good for turbo's
The engine components (internal) are not strong enough to support the extra power. you would have to change everything in there.
and like villero1834 said there are tons of external parts to change to.
not very cost effective.
just be warned if you do not change the internal workings of teh engine you can blow it sky high
That was what i was told....... so i traded it for a RA :P wahoooooooooo
How much of the internals need to be changed? Seeing as there are three motors like the 4b10 4b11 and 4b12. Two of which don't have any internal mods yet/ever.
Has anyone got a build thread on a 4b12 whos not blown it up?
PearceEVOix
Jan 10, 2012 01:50 PM
