I love turbo but I also love a supercharger
Hello do you think its possible to put a supercharger on a 2.0l 4 cylinder and how much gain could I get from a supercharger. And is rrm.com going to make a supercharger for our 08 lancer de,es,gts anytime soon. And please no negative feedback I truly hate negative feedback thank you
Is it possible? I don't see why not, with enough money you can do what you like.
Gains? I'm not sure about a 2.0 but toyotas 1.6 4AGE engine gained approximately 25hp running max 6psi from a supercharger. Those are factory setups too so a custom setup will likely see much better gains.
Will they make one? idk
Again anything is possible with enough money e.g. the NZer who put an LS2 into a 2006 MX5. The returns in power you get for what you spend would have me thinking twice though, it will be costly.
I don't have much confidence in the transmission for higher power, I've never seen a CVT used in a high power application, not even on factory cars.
http://www.jatco.co.jp/ENGLISH/PRODUCTS/CVT/index.html
there are a few factory cars like the 2012 nissan altima coup and the 2011 maxima. both have cvt's both have a 3.5 v6, altima is 270 at the crank maxima has 290. even one of audi's models such as the a4 has a cvt. the a4 has a 2.0 turbo with 210 at the crank. it just depends on of the tranny is made. oddly enough the company that makes our cvt also makes them for nissan.
a supercharger would be better on our motor and transmission than a turbo would be. but it wouldnt be likely we'd see one anytime soon.
while this is true they to make it for nissan and what not, they arent the same ones that are put in our car. the CVT in those are stronger than the ones in ours. if you've ever driven a nissan CVT you'll notice it drives a lot different than the ones on our lancer do. the CVT in ours are shared with cars like the dodge caliber, the more lower end HP cars.
boost from a SC would come more gradual curve than a turbo putting less stress on the tranny but gas mileage would be tanked with a SC.
yeah, the cvt for the 3.8 is a lot more beefy and has more cooling surfaces. i forgot to mention in my last post that they were not the same. but i am curious if they share common mounting points and weather or not they can be adapted to the 2.0 lancer. probably not because that cvt is huge, there might not be enough room.
A way to fit the 3.8 cvt tranny
Sounds like a plan dude
yep. i dont know much about CVTs and what not that would probably be a better question for EVO_SOUL but i would think there is some sort of way to beef up the tranny or share parts with the CVTs that are put in the Nissans. so in a way "build" it up to be one of those stronger trannys.
futurevowner
Lancer Aftermarket Forced Induction Tech
36
Oct 30, 2008 03:04 PM
kimmievo
Aug 15, 2005 07:07 AM
RIPPMODS
13
Apr 14, 2004 04:48 PM
topsnwbrdr
22
Sep 18, 2003 07:29 PM
