2013 lance es misfires pls help
I have 2013 lancer es and doing an evo x turbo swap. Reflased 2013 gsr rom to ecu then uploaded the 2013 gsr stock rom and now car turns on but misfires. Got new spark plugs but i might have mixed up the ignition coils and i read up on that and ppl are saying there is a particular order the coils go which is 4123 with the firing order of 1342. Is there a way to identify which number is which coil? Ppl say the number is on the part where u bolt on the coil. The number i see on my coils is 7 and 8 two of them says 7 the other 2 says 8. Does the order of the coil even matter? Going from left to right the first two arent sparking at all only the third and fourth is sparking. When i start the car it turns on for like 3 seconds and sounds horrible and then it dies.Any info would be great. Thanks!
But for a start the coils don't need to be "ordered" by part number they should all have the same part numbers to begin with. What your seeing is probably a casting number indicating what factory it came from or a batch number, *shrugs*. In any case the import bit is what order they plug into.
It looks like you got coil over plug ignition on these newer cars that's pretty nice. You should start checking to see if you have a coil problem or an electrical issue. Do this by swapping the non working coils with the working ones. If the problem flops to the other side the coils are bad otherwise its electrical in nature.
Since you mentioned you flashed you car with another rom try flashing back to stock. It is possible the ports used in the GSR rom do not match the ports on the base lancer. If this fixes the problem then you'll have to find someone to give you a custom rom.
lowboost
17
Apr 11, 2018 03:38 PM
juan5310
Lancer Troubleshooting
Sep 6, 2014 07:47 PM
TLeid91
Aug 21, 2014 10:45 AM
utripin
28
Nov 29, 2012 09:36 PM
