radio relocate
radio relocate
i wanted to relocate my radio to the little cuby hole in the bottom of the dash would i be abel to do this if i bought the thin for a in dash cd chancer if anyone has don this i would like some pics and a pic of the part i will need.
There was a post that contained the part # for the lower DIN part... I am too lazy to run a search for it, but if you run a search for it I'm sure you will find it.
here's one thread that could help:
https://www.evolutionm.net/forums/sh...ight=head+unit
do a search for din or head unit, there should be more threads with more info on this!
-Bob
-Bob
Originally posted by CTS 1273
here is a pic of what i mean see where the cuby hole is he has his radio there that is what i want to do what do i need to do it
There is a post detailing the replacement of your head unit... It clearly outlines what to do to get it out... Relocating down below may take a little work, but I'm sure it can be done with the proper length wiring harnesses and some patience.
dude..it's easy as hell to move it down there..all you do it literally take it out..move the wires and plug it back in. the main there i think everyone is concerned with is the lower din part # and where to acquire the piece. i myself have plans on doing this, when i get the money
I have a question for you lancer owners. since the evo is supposed to have the same interior as us lancer, I assume it will look like that picture posed above. My question is, if I wanted to mount a screen in the bottom cubbyhole for a CAMP system, would there be enough room between the face of the dash and the shift lever for the screen to be able to slide out of the slot and swivel up? it seems like a close call, or that you'd have to shift into 2nd, 4th or reverse simply to pull out the screen... but i'm only going off pictures. what do you real owners think?
its really easy to do this actually - - i got the trim piece at the dealer for about 75 bucks . . and i got a pioneer 7400 cd player . . . i just have to install everything now - - - im putting my new radio in the bottom and putting a couple gauges (a/f ratio and voltmeter from autometer (lunar series) for now) up top where the stock radio is now . . . ill take pics after i get it all put in . .whenever that happens
