stock sound system specs?
Originally posted by bobaab
so if i put in my Kenwood with 45 watts going through the 4 speakers, the stock speakers will explode. Right?
so all in all, if u're upgradin, get new head unit and speakers. not one or the other.
my actual question was the specs, but oh well, i dont care anymore
thanks everyone!
-Bob
thanks everyone!
-Bob
i disagree there i have infinity kappa componets now in front and when i turn it up i can hear the rears distort bad over my 2 subs and the speakers i think the rears are just as valuable as the front
well...that doesn't make sense to me. because with the stock system, when i turn it up i hear no distortion. so if i keep the stock head unit and rear speakers, why would they distort? did you upgrade your headunit? maybe that is pushing the rears too much. also, why not put the balance more in front? there's no reason to hear music coming behind you.
cup, that's a good idea too. and if that doesn't sound good enough, get an equalizer in the cubby hole the stock headunit doesn't have enough tone control in my taste..although it does pump pretty good bass. and equalizer would "make it more rock'n"
-Bob
-Bob
ok, but then where do i put my snapple? the cubby hole fits my cell so nice, it just lies there with the ear piece connected, and when it rings all i gotta do is reach in and push a button. and to call all i gotta do is push the side voice dial and speak i guess i'll sacrifice if i get an EQ.
in a surron sound enviorment would u have 2 speakers or 4 for great sound? i dont know about u but i choose 4 and when u have a lot of bass coming from rear it sounds better 2 add some vocals with it
and yes i do have a new head unit it rms at 22 watts so shouldnt push em 2 much maybee im not that deaf yet so i can still hear my rears maybe im just more picky but speakers require all 4 to make me happy plus if i add a dvd player later on itl be nice 2 have surrong sound with nice *** bass
i'm putting components up front. the tweeter will provide clear high frequencies, the 6.5" will give most of the vocals and midrange, and the sub in the trunk will provide bass. the front speakers are only going to drown out the rear speakers anyway.
if you have tons of money, fine, getting rear speakers won't make your stereo sound bad. my point is they are not needed.
trust me once u get your components in and subs and all and tuned good u will notice it distorting if u get a aftermarket deck the stock one cant push em even 1/10th they should be pushed at i havnt goten around but i have a lil 300watt amp laying around that im gonna use that 2 power those and when i get more money in like another lifetime get another matching set for rear also if u planing on doing what profile says with sub and components its gonna sound worse in my opnnion i did that with my amp in my old car and it masicvly depowers the subs rms
oh yeah, and if you add a dvd player in the future, and you want true dolby digital, 4 speakers isn't enough, you need a center channel for dialogue. but even still, in true 5.1 format, the rear speakers provide little more than environment effects. the front speakers do much more of the sound, which makes sense since you are watching something in front of you so you want to make it sound like it is right in front of you.
and bass shouldn't really sound like it is coming from behind you. bass is omnidirectional. it should be low, and deep, and all around. that's why it doesn't matter where you put a sub. but it is good engineering to put it on the floor, next to a wall, which will make it louder since it can resonate. if your "bass" sounds like it is coming from behind you, than you should check your crossovers to make sure you aren't putting mid-bass frequencies (which can bleed over into voice range) to your sub.
also, your rear speakers may be distorting if the signal you are sending them is clipping. if your headunit is pushing maximum wattage, it may be clipping the signal causing your speakers to be distorted. it is better to give speakers too much power but clean than just enough but clipped.
the front speakers will overpower the rears. i am very confident that this system will sound excellent. i plan to install after the new year, probably next thursday or friday.
