seeking florida alternator dealer
Old Jan 25, 2003 | 02:22 AM
Joka's Avatar
yea i got hooked up with a JL system from my dads hookups and im in need of a new alternator. the stock alternator isnt going to provide enough power, i dont know if i need another one bolted on, or just a replacement. i got a price of $450, but the guy said theres like some chip thats in the computer and no on the alternator or something? so it might not be possible to replace the alternator or bolt another one on. any information regarding the stock alternator would really be helpful. thanks.
Old Jan 25, 2003 | 02:23 AM
Joka's Avatar
forgot
i need a 200 amp alternator.
Old Jan 26, 2003 | 11:56 PM
jabrien00's Avatar
why don't you just use a capacitor it would be much easier to install I don't if this would help or anything
Old Jan 27, 2003 | 01:28 AM
cupOZnj's Avatar
cap doesn't provide more amperage. to increase amount of current that is provided to the stereo you need to upgrade the alternator.
http://www.eatel.net/~amptech/elecdisc/chargin2.htm
http://www.balmar.net/PDF/Alternator...or%20Guide.pdf - for info on selecting an alternator. (this is just info. i believe this is a guide for trucks. but it can provide some useful info)
contact a mitsu dealer and ask them about changing the alternator or for specs on the stock one. user manual may have some info too. as far as i know it's an 85amp. 200amp is heavy duty....sure you need all that?
Old Jan 27, 2003 | 01:32 AM
YellwTyper's Avatar
cup0znj, you ever go to the Hondavision website?
Old Jan 27, 2003 | 03:41 AM
AllShowES13's Avatar
not neccisarily cup, go to a shop that specializes in auto wiring and have them upgrade the wire that goes from the alt to the batt to 10 guage. that allows more current to flow to your batt which increases the power going to your stereo
Old Jan 29, 2003 | 05:48 PM
cupOZnj's Avatar
no, why?
and it doesn't make sense that the restriction on current supplied would be the alternator wire. most likely this wire can supply the given amperage. upgrading the wire may provide a small relief of current, but to get more amperage (as when adding high powered amplifiers) you need to get a larger amp alternator. but 200amp alternator is really big, not sure that it is particularly needed.
Old Feb 2, 2003 | 10:43 PM
Joka's Avatar
heh
heh yes i need a heavy duty alternator. jl w7's suck up most of the power in the car. i have one of those special batteries, and a battery isolator. my dad is the install manager of sound advice so i'm pretty sure he knows what hes doing. when he says we need a bigger alternator, then we need a bigger alternator.
Old Feb 4, 2003 | 08:08 PM
cupOZnj's Avatar
Re: heh
i don't doubt that you need a bigger alternator. just saying that 200amps is REALLY big. it's 250% bigger than the stock alternator. you should do some calculations on how much current you are drawing and figure out what size alternator would work best. if you really do need a 200amp, can i come listen to your system?
Old Feb 5, 2003 | 01:08 PM
Joka's Avatar
the forumla is: Wattage x 2 divided by voltage. 1600 x 2 = 3200/12.5=256 amps. so an 85 amp alternator is going to be able to push 256 amps of power? i dont think so
Old Feb 5, 2003 | 02:36 PM
Link286XT's Avatar
isnt it 14 volts?
Old Feb 5, 2003 | 05:04 PM
cupOZnj's Avatar
watts=voltage * current.
current = watts/voltage
and by the way, you are forgetting that it is an AMPLIFIER. it's 1600 musical watts. and the alternator is more like 14.4-15 volts. please do not answer if you have absolutely no idea what you are talking about. you didn't even get the right formula. every thing you said in that statement is completely ridiculous.
Old Feb 5, 2003 | 05:06 PM
cupOZnj's Avatar
to draw 256 amperes you would need a 3840 watt refrigerator. and amps isn't a measure of power, it's a measure of current. to get power (wattage) you multiply by the voltage, or multiply by the square of the resistance. if you are pushing 1600 watt amplifiers, you do NOT need a 200 amp alternator. get some caps.
Old Feb 5, 2003 | 05:57 PM
MrSpace's Avatar
what is your amp?
go check the specs it will tell you how many current it draws. o way you need 200 amps. And I'm curious what amp is giving 1600 Watts RMS at a low distortion... Seem you count too much on product specs
Etienne
Old Feb 5, 2003 | 06:19 PM
MrSpace's Avatar
let's say you use the V12 high end Alpine amps
MRV-F540 ... 60A amp fuse (or two 30A fuses in
parallel)
that's from the owner's manual at http://ecominet2.alpine-usa.com/html...rv-f540_om.pdf
so don't tell me you need a 200 amps alternator if the biggest amps will never draw more than ~60 amps.
140 amps will be more than plenty (since your 85 have already more than it needs... Probably a 120 amps will be enough.
Etienne
Quick Reply: seeking florida alternator dealer
