amp probleam
![Angry](https://www.evolutionm.net/forums/images/icons/icon8.gif)
Can someone help me out I had to take my amp wiring apart because I had to get my ralliart struts installed and when I put it back together my amp fuse keep blowing I tried to take the negative battery cable off and put the fuse back and it blew again I really don't know what is up with this ish........ I'm hoping that there is nothing wrong with the amp itself and any help would be appreciated
![Dunno](https://www.evolutionm.net/forums/images/smilies/dunno.gif)
it sounds like the wire is touching something else electrical or ur ground isn't hooked up properly. if i were you i'd take another look at the entire wire settings. if that doesn't help, time to take it to a professional.
check all your wires 50 times. have someone else check the wires another 50 times. if you still don't see anything wrong, call the amp manufacter and see if you can get it replaced under warranty (if it is) or get some tech help.
HKSevolutionNYC
Aug 4, 2006 12:55 PM
