Help! Path of 4 gauge wire from batt to trunk
Old Mar 9, 2006, 06:52 PM
Destroyer101's Avatar
bored? I just ran it throug that rubber thing. And ran it where the other wires went, all the way to the back of the car.
no drilling involved.....for me atleast?
Old Mar 9, 2006, 06:54 PM
camaro379ss's Avatar
just drill a hole on the driver side in the firewall and run it on that side, it will save you money by using less wire.
Old Mar 9, 2006, 06:55 PM
doesn't drilling a hole in your firewall void the warranty?
Old Mar 9, 2006, 06:56 PM
no, i have plenty of holes drilled in my firewall and all three dealerships know about it and dont give a crap.
Old Mar 9, 2006, 06:57 PM
oh, lol thanks.
Old Mar 9, 2006, 07:03 PM
AndrewMMueller's Avatar
i was pondering the firewall drill.. but as for where taht wire went through... theres no way theres a perfectly sized 4 gauge hole... facing conveniently UPWARDS just waiting for a wire...
you had to drill through that thing.
Old Mar 9, 2006, 07:16 PM
no lol i just grabbed a knife and had my freind look at that spot to see where i was poking, and he said he saw something moving so i just slit a hole in it and twisted the knife, and ran the wire throught lol, might be a little ghetto but i don't care.
the rubber thing isnt perfect size for a 4awg its like the size of a baseball.
sorry i misunderstood you in your earlier post.
Old Mar 9, 2006, 09:21 PM
comatose721's Avatar
yeah.....there's several wires from the ECU and SRS in there i believe. that's not the place to just be cutting around.....behind the passenger side strut tower there is a grommet in the firewall. simply pop it out and the wire will feed just behind the glove box. if you already ran that much excess wire-->just go the extra 2ft and be safe. it's all a preference thing. i would just hate to see something accidently get cut the way yours was ran. (that is if somebody else decides to mimic it)
Old Mar 10, 2006, 05:49 PM
i went the drivers side fender rout.. worked great till i had to get the wire back to the INSIDE of the car.. that grommet was a B I T C H... ended up actually popping the grommet OUT.... cause its huge and has wires already in it... then just ran it through the hole and wedged the gromet in the best i could while screaming obscenities at the steering column cause it was the only thing there to yell at...
im not sure how you other guys got through the fender.. that was no small task... took about 30 seconds to run it once i got it to the kick plate... btw.. 60/40 fold down seats made it DAMN easy to slide that wire under the seats and into the trunk...
im starting work on the install tomorrow.. supposed to be 70 outside... in march... so im gunna get crankin.. ill have pics soon
Old Mar 10, 2006, 07:00 PM
I tried the grommet by the the glove box. The wire wouldn't feed down I tried for like 10 min so then i just found that 1.
Old Mar 10, 2006, 07:04 PM
what one.. the one on the driver side fender?
Old Mar 10, 2006, 08:55 PM
dont be so afraid to drill in the firewall just feel for an open spot and make sure its clear on the other side....and boom u did it....ur making a bigger deal out of it than what it really is. There is plenty of room next to ur driver side strut tower. as a matter of fact there is so much room that i have 3 holes there and no problems.
Old Mar 10, 2006, 09:04 PM
grubiaco's Avatar
camaro do you mind take a pic?
Old Mar 11, 2006, 05:34 AM
when you feed the wire you need to make sure its being fed downwards through the hole AND your glove box needs to be removed. otherwise, you'll never see that wire.
Old Mar 11, 2006, 06:16 AM
yea i'll take a pic just give me a couple of days to find a camera.
Quick Reply: Help! Path of 4 gauge wire from batt to trunk
